Old 01-09-2006, 12:43   #1
RS Edd
Car: Evo IX GT
Autronic SM4 PNP Boards
I gather there seems to be some delay in the supply of Autronic SM4 plug & play boards coming into the country.
Does anybody know (Mr Shead / Nick @ NR possibly ?) whether the pnp setup will be available for the VII & VIII as well as the IX once a more substantial supply comes on stream ?
RS Edd is offline   Reply With Quote
Old 01-09-2006, 17:25   #2
Madevelopments
Car: Evo 6 under construction
The Evo 7 has a 4 plug Ecu connector and the 8/9 has a 3 plug,
Ths SM4 will have a 3 plug connector for the later car,
I will post up when they are ready.
Mark
Madevelopments is offline   Reply With Quote
Old 04-09-2006, 13:03   #3
RS Edd
Car: Evo IX GT
Thanks for the response Mark.
So the plug & play SM4 will only be available for the VIII & IX - looks like I might not get the VII after all
vB code is On
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
