Old 02-12-2005, 00:53   #1
riggy56
Car: 05 evo VIII
throttle hang on VIII
Hey fellas, back home in the lucky country ( Australia ) mmmmm nice n warm!!! Believe you're all freezin your bits off? I'll get to the point now.. Some of the guys here are having probs with throttle hang on their motors (makin' em look n feel like plonkers ) givin em rough gear changes n all!! Anyone had the prob n sorted it?? Been to MMA but they recon on the Aus spec cars it's there for a reason ??? Any suggestions?? ( keep it clean )
Riggy ( The Manc down under ) RIP George
riggy56 is offline   Reply With Quote
Old 02-12-2005, 07:01   #2
Paul_G
Paul_G's Avatar
Car: Nissan GTR. Here at last.....
So, what reason did MMA give?
Paul_G is offline   Reply With Quote
Old 02-12-2005, 08:00   #3
DJ-Dulux
Car: Ford Transit Connect - feel the power!
There are a few threads on this, reading between the lines most people belive it is due to a faulty Idle Speed Control Valve (error code 505 on the ECU diagnosis). Apparently common fault on other CCC vehicles too. Mine also hangs on and even increases the revs when lift off and I will be getting dealer to investigate based on the above at next service, i'll post if I get it sorted.
Dupe...
DJ-Dulux is offline   Reply With Quote
Old 02-12-2005, 11:19   #4
Paul_G
Paul_G's Avatar
It would be usefull to hear what the dealer says one way or the other.
One general question, does anyone know if the dealer can still get error codes from an ECUtek'd ECU?
Old 02-12-2005, 11:31   #5
xlr8
xlr8's Avatar
Car: Reliant Kitten
can't see why not
it's only the maps that are changed/re-flashed
& that shouldn't affect the OBD systems
xlr8 is offline   Reply With Quote
Old 03-12-2005, 12:04   #6
riggy56
Car: 05 evo VIII
The reasons they gave were:
1/ By holding the revs between changes it gives better fuel economy.
2/ It stops fuel surges being dumped into the cat, therefore not breaking emission standards.
So whwt do you recon to that???
Riggy (the Manc down under )
