Old 17-08-2005, 18:24   #1
Schumacher
Schumacher's Avatar
Car: FQ300 VII
Question bleeding the AYC in the transfer box
Hi everyone
I took my Evo 7 to my local mitsubishi dealers today to have all the oils changed.
All was going well. finally it was time to bleed the AYC.
they bled the rear diff clutches ok but the front transfer box wouldn't bleed!
there was only small air bubbles coming out, and the pump made a noise like it had shut off due to reaching max pressure.
I am now a little concerned due to the transfer box being an expensive item?
Please can anyone shed some light on the problem as i have only owned the car for 2 weeks and I dont like nightmares
Andy
Schumacher is offline   Reply With Quote
Old 17-08-2005, 18:51   #2
dssean
dssean's Avatar
Car: AUDI RS4 ,MK1 RS2000 ESCORT ,SOMETHING IN THE PIPE LINE ????!!!!!
i've been told that the center diff bleed itself as its lower than the resevoir. but dont take it as gospel mate,
anyway if the dealer let you take the car away and the three acd lights on the dash are not on, i wouldnt worry too much.
sean
ARS4E HOLE
dssean is offline   Reply With Quote
Old 17-08-2005, 23:30   #3
Schumacher
Schumacher's Avatar
Car: FQ300 VII
Thanks for that but i forgot to mention that the dealers kept the car and i had to get a lift home
so I am now waiting for them to have another look at it hopefully tomorow.
Old 21-08-2005, 23:20   #4
Schumacher
Schumacher's Avatar
Car: FQ300 VII
Talking
big relief it was just a blocked nipple
