Go Back   Mitsubishi Lancer Register Forum > Marketplace > MLR Group Buys
Old 05-01-2017, 09:17   #1
Darin
Administrator
Darin's Avatar
Car: Ex-works Lancer Turbo WRC, 'Long Way Round' Shogun and a few bikes
Save 300 on KW V3 Fully Adjustable Suspension from Indigo-GT
Thanks to Ant at Indigo-GT MLR members can save almost 300 on some of the best quality KW fully adjustable suspension available
State of the Art Technology
The separate and independently adjustable rebound and compression damping allows for an individual suspension setup for different uses and preferences. The unique patented system with its two-stage valves allows a rebound damping adjustment (comfort) and a compression adjustment (driving dynamics) in the low-speed range while the high-speed range which controls the driving safety, is fixed.
Damping technology with individually adjustable rebound- and compression technology
inox-line* stainless steel technology
Individually height adjustable
Adjustment parameters approved by the German Technical Control Board (TV)
High-quality components for long durability
Infinitely variable rebound damping adjustment
14-way adjustable compression damping
Unique, individually working damping force adjustment
Comprehensive documentation for easy use
Compression and Rebound Adjustment
As far it is vehicle-specifically possible, the rebound damping is adjusted by a spindle at the end of the piston rod. Mainly, the traction phase (rebound) controls car body vibrations and also influences handling and comfort in the low-speed damping range. By using the traction phase adjustment, the vehicle can be adapted to the requirements of the driver. Moreover the driving behavior can be regulated from comfortably rolling to sporty and tense with improved road holding characteristics
The compression phase adjustment is carried out at the lower end of the shock absorbed via our patented multi-purpose valve. The large number of pre-set parameters of this valve allows for a wide range of adjustment for individual use. The unique low-speed compression adjustment significantly distinguishes this technology from any other. In this compression range, the driving behavior of the vehicle is drastically influenced. An increase of the damping power supports the vehicle already during compression and therefore avoids rolling and pitching. The directional stability is significantly improved.
The Group Buy & Savings:
The Group Buy will run until the end of January 2017 and we need 5 orders to get these discounts from Ant at Indigo-GT
Evo 4-6 1860 - Group Buy price: 1581.00 Save: 279
Evo 7-9 1860 - Group Buy price: 1581.00 Save: 279
Evo X 1980 - Group Buy price: 1683.00 Save: 297
Ant is then offering 12.5% discount on all other KW suspension kits, eg:
KW Clubsport inc Topmounts Evo 4-6 2762 - Group Buy price: 2416.75 Save: 345.25
KW Clubsport inc Topmounts Evo 7-9 2762 - Group Buy price: 2416.75 Save: 345.25
Please add your name, the kit you want and your car details car below, or feel free to ask any questions. Ant will be watching the thread and will answer them asap.
Darin is offline   Reply With Quote
The Following User Says Thank You to Darin For This Useful Post:
RichW (07-01-2017)
Old 05-01-2017, 10:11   #2
Ability over Boost
antony@Indigo-gt's Avatar
Car: Cayman GT4, MK7 Golf R and Tiguan R
Thanks Darin
antony@Indigo-gt is offline   Reply With Quote
Old 05-01-2017, 10:53   #3
danb87
danb87's Avatar
Car: Evo 8 fq300mr 547hp blouch 760xtr
so how do these compare to others etc?
danb87 is offline   Reply With Quote
Old 05-01-2017, 10:56   #4
Ability over Boost
Quality and ride is fantastic and we have been dealing with KW for 5 years and not had a warranty issue.
Old 05-01-2017, 16:45   #5
DazK-EvoIV
Seor User
DazK-EvoIV's Avatar
Car: Evo IX MR FQ-360 & Stage 4.25 Nissan R35 GT-R
I've got (hybrid) KW V3s on the GTR and they are fantastic! I haven't tried them on the Evo so cannot comment directly but I would be surprised if they were not equally as good ...
Not sure if this helps much but it is a little information for you.
DazK-EvoIV is offline   Reply With Quote
Old 05-01-2017, 20:44   #6
ekme
Oh damn I'm booked in at indigo in a few weeks as well........must resist urge
ekme is offline   Reply With Quote
Old 05-01-2017, 20:47   #7
Ability over Boost
I may have to put a set by the Settee ��
Old 05-01-2017, 21:06   #8
danb87
danb87's Avatar
cheers daz
Old 06-01-2017, 23:42   #9
EtsonEvo
EtsonEvo's Avatar
Car: evo 6
Got a set of these a few months ago not had a chance to try them on track yet but
The build quality is spot on
Evo 7 Custom Project
EtsonEvo is offline   Reply With Quote
Old 07-01-2017, 17:38   #10
Arronevo8
Do these come with top mounts
Old 07-01-2017, 17:46   #11
VI_Shooter
Regional Organiser
VI_Shooter's Avatar
Car: Stock Silver VI GSR from Nippon!
On a VI, do you just use the OEM/Ralliart top mounts front and rear?
"Do not meddle in the affairs of Lancers, for they are rally and quick to 60"
VI_Shooter is offline   Reply With Quote
Old 07-01-2017, 18:13   #12
Ability over Boost
You can use the topmounts on the car or Ralliart They come with camber adjustment still though.
The Following User Says Thank You to [email protected] For This Useful Post:
VI_Shooter (09-01-2017)
Old 08-01-2017, 02:31   #13
Andrew B
Andrew B's Avatar
Car: IX MR360
Could these come with preferred spring rates
Andrew B is offline   Reply With Quote
Old 08-01-2017, 08:37   #14
Ability over Boost
I will ask. Normally we supply some extra springs but let me know what you want and I will see what I can do
evobull (Yesterday)
Old 10-01-2017, 22:16   #15
nickyd150
Car: EVO X SST 300
Very pleased with my KWv3s on my Evo X, supplied and fitted by Indigo-GT.
They set up the corner weights also.
nickyd150 is offline   Reply With Quote
