Old 29-01-2013, 21:20   #1
Stallion
Moderatorô
Stallion's Avatar
Car: (s)... Yes I have a few in my collection ;-)
Wing Mirrors Folding In...
Mate of mine is having a few issues with his wing mirrors on this Evo 9 not folding in when he depresses the button.
he tells me its like there powered by Duracell and there just about to run out?
Could it be the motor?
Relay?
Main Battery?
Advise welcome.
Stallion is offline   Reply With Quote
Old 29-01-2013, 21:30   #2
tones61
MLR user/mot tester
Car: vw polo R line,dax rush cosworth powered,ZX6R,
sounds like seizing motors,
if its got wheels or boobs,,,sooner or later its gonna cost ya!!!
tones61 is offline   Reply With Quote
Old 29-01-2013, 21:33   #3
Lee5
Moderator
Lee5's Avatar
Car: Range Rover Sport~Porsche 911
Just tell him to open the window and give it a good yank
1st 500BHP E5 in the UK Running on Speed Density on Stock H8 Ecu
MLR Sprint Scrutineer
E5/6 Ecu SD Mapping Info Here & HERE
Lee5 is offline   Reply With Quote
The Following User Says Thank You to Lee5 For This Useful Post:
corky_79 (29-01-2013)
Old 29-01-2013, 21:33   #4
Stallion
Moderatorô
Stallion's Avatar
LOL im sure he has done this - just wanted to know what is the problem & how he fixes it
Old 29-01-2013, 21:36   #5
tones61
MLR user/mot tester
strip out and try to free with wd40?,
The Following User Says Thank You to tones61 For This Useful Post:
Stallion (29-01-2013)
Old 29-01-2013, 21:50   #6
Stug360
Car: A Pure IX 360MR
+1
Either the motor is on its way out or part of the mechanism is jamming causing the motor to struggle to operate it. The mechanism is mostly cogs, all of which are metal bar one IIRC. The plastic one is held in place by a metal pin which can shift slightly due to the plastic wearing away causing the plastic cog to jam. Just strip it down and hava look. If theres no sign of wear then probably the motor on its way out. Should be able to swap it out with a working one.
Stug360 is offline   Reply With Quote
The Following User Says Thank You to Stug360 For This Useful Post:
Old 30-01-2013, 19:48   #7
leecavturbo
leecavturbo's Avatar
Car: Evo8 MG Full Cosworth 2.2L/r stroker,Blouch xtr760,syvecs 9.8sec 30-130
shimmed mine. As said steel spindles are just lubed and slot into rebated plastic. The force/turning widens the slot over time. The cogs then rub on surrounding housing making hard work for the motor until its safety release stops the motor so it doesn't burn out.
Easier to buy but if you fancy tackling it. Dremmel the slot to fit a shim to stop shaft movement
leecavturbo is offline   Reply With Quote
Old 30-01-2013, 20:01   #8
matt_k
Car: Evo IX MR FQ360 HKS #103
I stripped mine down, and re-lubed, see if this helps
http://www.lancerregister.com/showthread.php?t=437482
matt_k is offline   Reply With Quote
Old 30-01-2013, 20:19   #9
squeakyclean32
squeakyclean32's Avatar
Car: Evo 6 TME.... White E9 GT....
A handy thread ...our drivers side mirror sticks. Another job
squeakyclean32 is offline   Reply With Quote
