Old 10-05-2012, 13:03   #1
AndyS13
AYC install evo 8
I sent my ayc pump away for a refurb and should be getting it back tommorow. Ive got the car jacked up and the ayc fluid ready to use along with evoscan in order to bleed the system.
On removing the pump I also drained the ayc fluid from the rear diff which will be getting refilled was this necessary? Do I need to do anything to the ayc fluid in the acd does it need bled etc? Or do I simply fit new pump, fill up rear diff with ayc fluid, fill up ayc bottle in the boot and proceed to bleed the nipples on the rear diff?
AndyS13 is offline   Reply With Quote
