Go Back   Mitsubishi Lancer Register Forum > Marketplace > Trader Discussion
Old 19-03-2012, 16:36   #1
scubaladdie
Car: Evo VI GSR, Compomotives,Teins,Carbon Twin-Plate,HKS Cams 396/400
Boanerges Performance
Just picked my VI up from Stevo_V at Boanerges in Auchinleck, after dropping it off a few weeks away follwing 16 months parked up SORN'd
I have to that Steve is a true example of how business should always be conducted, he kept in touch regularly to update me on progress, and reported any little issues he found before fixing them.
I had quite a lot of work done consisting of:
Oil and filter changed
Gearbox and transfer box oil changed
AYC fluid changed
Brake fluid changed
Brakes stripped and cleaned
Coolant changed
Plugs, air filter and fuel filter changed
Ralliart thermostat and HEL clutch line fitted
Rear discs and XP8 pads fitted
MOT test
Diagnose and fix ABS fault
Fit Varta battery
On top of this, I'd asked him to remove the underseal from under the spare wheel well as when I undersealed it there was a couple of small bubbles I couldn't remove.
Not only did he do this, he wirebrushed, cleaned up and painted/undersealed the front crossmember, north - south bar, fuel tank shield and AYC pump shield.
Replaced my rattling rear droplinks
Traced an annoying squeak under the bonnet that's been there for years, and fixed it by cleaning up the aux tensioner
Modified the hanger on my exhaust as for years it's rattled against my Whiteline rear ARB on idle... totally fixed now
Plus all the really small touches, like fixing several rattles from inside the cabin, wrapping the can of Tyre Weld in my glovebox in cloth to stop it banging about, washed the car, even remembered to set my clock after fitting a new battery!
The bill was less than expected, which makes a nice change
The car feels like a new car, all the little niggles have gone and I can highly recommend Steve for the extremely thorough work he does on your car and his professional and courteous manner with his customers
Think I've worn my keyboard out now
So thanks again Steve
scubaladdie is offline   Reply With Quote
Old 19-03-2012, 18:38   #2
stevov
stevov's Avatar
Car: EVO 5
was a pleasure working on your car mate.you keep it well tidy. a credit to you
stevov is offline   Reply With Quote
Old 19-03-2012, 18:52   #3
davie-evo4
Regional Organiser
davie-evo4's Avatar
Car: A slow yin
Wow,that's some list mate,well done Steve.
That you got a spare ramp now.
davie-evo4 is offline   Reply With Quote
Old 19-03-2012, 22:11   #4
scubaladdie
Cheers mate
Old 19-03-2012, 23:30   #5
michty_me
michty_me's Avatar
Car: Forged Evo X CT-500
Nice one Steve! Keep up the good work
michty_me is offline   Reply With Quote
