Go Back   Mitsubishi Lancer Register Forum > Marketplace > Gold & Silver Option MLR Traders > GB Enterprises
Thread Tools Search this Thread Rate Thread Display Modes
Old 11-01-2012, 20:00   #16
Furiousfurlong
Furiousfurlong's Avatar
Car: Evo VIII 400/400
PM me please
Delivered to the Isle of Man
Kev
Sold my VIII with 386bhp/359Torque
Carbon Bits and Bronze Rota Torque Drift 18x9.5
Furiousfurlong is offline   Reply With Quote
Old 11-01-2012, 20:22   #19
Goginawa
Zero Fighter
Goginawa's Avatar
Car: EVO IX FQ 320
Grant ,can you pm me price for Evo 9,someone I know might be interested
MAPPED BY ORACLE
FOR SALE ITEMS APRILIA SUPER MOTOEVO 9 OEM SPRINGS
Goginawa is offline   Reply With Quote
Old 11-01-2012, 20:26   #20
Grant620
Gizzmo Distributor
Grant620's Avatar
Car: EVO IV GSR (breaking) / EVO VI Race Car
On its way.
Grant620 is offline   Reply With Quote
Old 11-01-2012, 23:16   #21
Dave-Cee
Climate Changer
Car: Evo IX FQ 340 PLG Leccy Bloo Mapped by grayw 389/367
Great review Grant.
I've been banging on about mine ever since I had them fitted.
I'm running ADO8's what tyres did you test them with?
Dave-Cee is offline   Reply With Quote
Old 11-01-2012, 23:18   #22
Grant620
Gizzmo Distributor
Grant620's Avatar
I'm just running Eagle F1s at the moment, but run 888s on track.
I imagine on sticky rubber the effect will be compounded.
Old 11-01-2012, 23:28   #23
Dave-Cee
Climate Changer
I had Eagle F1s a while back on stock Billies and found them a bit soft on the sidewalls.
I had the ADO8's on when I had the Ohlins fitted and the steering feel is so precise so I guess the R888's should be on par with them?
Old 13-01-2012, 22:53   #25
Grant620
Gizzmo Distributor
Grant620's Avatar
Originally Posted by Bren@Apex View Post
I believe Grant now not only has the adapters to reduce hub bolt diameter to the suitable size and the spacers to allow the 789 bottom mount to mate to the 456 hubs but he is now able to supply 456 camber top plates should they be required.
Our bottom adaptors/spacers are a light press fit into the damper. The top hole is an oval shape so that it matches the damper and the hole in it is also oval, meaning you still have adjustment for camber there as per OE.
They are made from HE30 aluminium and are not able to move, creating a solid platform for the 12mm bolt to pass through.
Drilling the hub is not something we recommend. Mitsubishi made the hubs 12mm for a reason.
We went this route for 3 reasons:
1) The hubs retaining the 12mm hole means that if you change to a different suspension brand later on and they are available in the 4/5/6 configuration you can fit the matching suspension again.
2) The adaptors can be pressed back out converting the dampers back to 7/8/9 configuration.
3) You do not need to purchase a 14.1mm drill bit and be ultra careful drilling the hub. If you do NOT drill the hole perfectly straight a side load will be placed on the bolt when it is located. This would be worse than using a bolt that's too short!
We can supply with the 4/5/6 top mounts. We didn't fit those on our own car as we feel there is no need, but will supply them with any kit destined for a 4/5/6.
We supply longer 12mm bolts to allow the correct thread engagement. The stock bolts from the 4/5/6 are too short.
We supply a bracket to locate the ABS wire and brake hose.
Our kits are fully assembled with springs, preload set, damping adjusted, ready to install with no further assembly needed.
Old 14-01-2012, 06:24   #26
eagle-evo5
Senior Abuser
eagle-evo5's Avatar
Car: Evo V GSR & Pajero 2.8TD work horse
Send a message via MSN to eagle-evo5 Send a message via Skype™ to eagle-evo5
Grant do you do them without the oval? Reason I ask is if you change a part on the car and you have to remove the bolts it would upset geometry, yes? Or am I talking 5h1t?
My Feedback Thread >>> http://www.lancerregister.com/showthread.php?t=450897
eagle-evo5 is offline   Reply With Quote
Old 14-01-2012, 11:47   #27
Grant620
Gizzmo Distributor
Grant620's Avatar
We considered doing them with an oval outer and round inner for that very reason, but reasoned that people would dislike the non-oe nature!! DOH!
We could make some with round inners though yes.
Old 19-01-2012, 11:53   #28
Grant620
Gizzmo Distributor
Grant620's Avatar
OK, 1 week on now.
Still amazed by these.
Did some slight tweaks to geometry yesterday (Thanks to FCM Alignment!) and fiddled with damping a ride height a little.
Overall, I can safely say that these are AWESOME.
Get some bought - you won't regret it!
Old 17-03-2012, 05:51   #30
Lolo la Torche
Lolo la Torche's Avatar
Car: Full Black Evo IX 470HP
They are my next buy!
Just wait to save money, march was the brake month
Lolo la Torche is offline   Reply With Quote
Search this Thread:
Advanced Search
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
