Thread Tools Search this Thread Rate Thread Display Modes
Old 29-05-2011, 20:37   #1
DarwinsChoice
Are lightweight plastic Fuel Tanks illegal ?...
I have searched this forum and i can't find any mention of an aftermarket lightweight fuel tank (perhaps made of GRP or carbon fibre) as a direct replacement to the standard fuel tank in the same position ?
I'm looking for the lightweight options to replace the fuel-tank, prop-shaft and exhaust on my VI
Is it illegal to have a non-steel tank under the car, is that why there are no lighter options to the standard tank position ?
cheers guys
Ren
DarwinsChoice is offline   Reply With Quote
Old 30-05-2011, 15:27   #2
coskev3
Car: Scotia white Evo V
Cant be illegal,my 309 and 306 pugs have plastic tanks as standard,as do lots of cars these days
coskev3 is offline   Reply With Quote
Old 30-05-2011, 15:36   #3
super rover
acting daft since 1969
super rover's Avatar
Car: 4.5 RS RALLY CAR + 09 TRANSIT
you can buy an UNDERFLOOR bag tank from ATL ,massively expensive and not that light
personally the steal tank isnt that heavy ,on its own ,i bet youll find NOTHING lighter
THE ONLY EVO 4.6 RWE
Old 30-05-2011, 15:38   #4
K
gary nevile pure incest
K's Avatar
Car: EVO 7 RS S-P-R-I-N-T->
cheers guys
Ren
What are you trying to achieve?
Fighting for peace is like ******* for virginity.
K is offline   Reply With Quote
Old 30-05-2011, 16:13   #5
Madmac
Twincharger Guru
Madmac's Avatar
Car: Evo 5 850hp Hillclimb twincharger & Manual Legnum VR4 Type S
Don't fancy using a GRP or carbon fibre fuel tank on any car. Too easy to split and tear open in an impact. Plastic tanks are fitted to a lot of cars these days but i think they have to be approved and tested as part of their type approval.
If it's weight you're trying to remove, use a basic alloy tank in the boot with the swirl pot integral below, cuts out the need to plumb in a swirl pot and pumps, plus you can avoid surge, even with only a few litres in the tank
www.Wallaceperformance.co.uk
"Understeer" is when you hit the fence with the front of the car. "Oversteer" is when you hit the fence with the rear of the car. "Horsepower" is how fast you hit the fence. "Torque" is how far you take the fence with you.
Madmac is offline   Reply With Quote
Old 30-05-2011, 21:06   #6
DarwinsChoice
Ah interesting !!
Well Kieran i'm trying to achieve as much lightening as possible with these heavy Evo's
Sounds like there is nothing which is much lighter to directly replace the standard tank so i'll leave that alone and change some other stuff instead
I may, at a time further down the modded line, change to a alloy tank in boot type set-up, but not yet !
thanx for the input guys, love the work u done to your evo's and pugs coskev
I used to have the legendary 205 1.9gti still miss it to this day !
Ren
Old 30-05-2011, 21:09   #7
K
K's Avatar
Ah interesting !!
Ren
you could reduce the size of the tank half it down etc etc takes a bit of fabrication
Search this Thread:
Advanced Search
Similar Threads
AEM Hi Volume Fuel Rail 03-05 Mitsubishi EVO VIII / IX - P/N: 25-131BK DanielN Private Sales - Parts 9 14-08-2009 14:05
Fuel tanks Evo VIII ?? windowlicker Technical Questions 0 02-04-2008 08:03
Green plastic bit inside fuel filler neck evo baz Lancer Chat 2 08-11-2007 18:00
Dawes device: be carefull rsnk Engine / Turbo 29 07-03-2002 20:04
Improved Air Intake |EQU| Fuel cuts ? Evo4Jon Technical Questions 27 26-02-2001 17:42
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
