Old 01-03-2011, 09:18   #1
Evo_Rob
Nearly there!
Car: EVO VIII MR FQ-300, tweaked by A.i Autosport :-)
Knocking - Front L/H/S turning left
Hi all,
any suggestions as to cause of knocking/rumbling from front L/H/S when turning left, usually notice when tighter turn at low speed?
Going to get this checked at garage at weekend just looking for suggestions/common fault ie, drop-link, anti-roll bush or top mount???
Cheers in advance
Rob
Evo_Rob is offline   Reply With Quote
Old 01-03-2011, 18:05   #2
granty
Car: EVO VIII FQ320MR with extra go
mine has been doing the same for a while, changed all of the suspension components made no difference.
Done brands on sunday and its stopped knocking, WEIRD LOL
granty is offline   Reply With Quote
Old 02-03-2011, 19:59   #3
Evo_Rob
Nearly there!
Still going to get this checked but should add that I had set Tein lowering springs fitted 4weeks ago and after reading few posts on here about them I'm wondering if thats them just settled in and causing the problem
Old 02-03-2011, 20:44   #4
stevov
stevov's Avatar
Car: EVO 5
hi mate check the top mount bearings also try spraying the strut with wd40. if you want to stop by sat afternoon give a shout
stevov is offline   Reply With Quote
Old 02-03-2011, 20:59   #5
Evo_Rob
Nearly there!
cheers stevov, i'll have a look at what u said + if got other bits by sat i'll def arrange to pop round
Old 06-03-2011, 17:05   #6
Evo_Rob
Nearly there!
Big thanks to stevov, approx 1hr visit and we had resolved the prob
Turned out that was a mistake made when had the springs fitted, the spring base and top plates were not lined up correctly (2 holes), so removed the strut and corrected, no more knocky knocky
Aswell as this stevov replaced the coils/leads with spares and the missfire on boost also gone. Happy Days + again big thanks to Stevov for his help and very reasonable prices
Old 06-03-2011, 17:36   #7
stevov
stevov's Avatar
Car: EVO 5
glad we found the problems and put a smile back on your face mate
Similar Threads
EPR January Stock List (BIG LIST) EPRacing Silver Option Traders 49 21-12-2015 17:17
Carbon Front Left Mud Flap pastymaster Wanted 2 08-02-2010 18:18
Help - Knocking From Front Suspension? Boysey Technical Questions 22 01-05-2009 22:03
Damn knocking when turning right!!! David27 Lancer Chat 9 07-12-2007 21:25
Front Suspension Knocking Sound!! EVILEVO Technical Questions 21 24-05-2001 17:08
