Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 10-01-2010, 00:20   #1
granty
Car: EVO VIII FQ320MR with extra go
gear oil change
does the gearbox and transfer box have separate drain and fill points?
where are they located?
what oil and how much?
granty is offline   Reply With Quote
Old 10-01-2010, 00:44   #2
MotoIntrest
Car: Evo 4
need a large allen key/socket for the gearbox and 3litres will cover it(2.8).
drain and filler plugs are located on the side of the box and are gold(ish) in colour. facing the pass front wheel so to speak.
17mm(fillerplug) and 24mm(drain plug) for the transfer.
drain is on the underside facing towards the floor and filler is on the side near the driveshaft on the drivers side. facing drivers front wheel.
hope that helps? if not i'm sure there is a how to with pics on here somewhere.
MotoIntrest is offline   Reply With Quote
Old 10-01-2010, 00:49   #3
granty
how much does the transfer box hold?
what brand of oil do you recommend?
Old 10-01-2010, 01:14   #4
MotoIntrest
Car: Evo 4
transfer box is about 1litre(0.6litre) and workshop manual says 80-90 or 90 lsd oil.
75-85 or 75-90 for the gearbox.
Old 10-01-2010, 09:39   #5
RSgeoff
RSgeoff's Avatar
Car: 2003 VI GSR.
Biggest problem is getting the new oil back in !
I used a piece of garden hose, one end on the filler hole, the other up to a point where I could pour the oil into.
RSgeoff is offline   Reply With Quote
Old 10-01-2010, 14:01   #6
granty
can I use castrol syntrax semi synthetic 75w90 for all the transmission
Old 10-01-2010, 19:36   #7
RSgeoff
RSgeoff's Avatar
Car: 2003 VI GSR.
Only for the gearbox & transfer box. You need the special lsd oil for the rear diff.
Old 10-01-2010, 21:17   #8
Uncle Winnet
Car: white evo v gsr forged 2.0L engine
Uncle Winnet is offline   Reply With Quote
Old 10-01-2010, 23:13   #9
MotoIntrest
Car: Evo 4
the gearbox pic above is wrong as that is a 5speed box. the drain is in almost the same place but the fill is v.different.
Old 11-01-2010, 00:09   #10
stuey68
Car: VI Ralliart safely tucked away in the garage, BUT COMING OUT NEXT MONTH :) WAHOO
I use Millers CRX 75 90 for gearbox and Silkolene Syntrax 75 90 in both tranny and rear diff. Both are highly recommended
stuey68 is offline   Reply With Quote
Old 13-01-2010, 19:50   #11
granty
how about castrol for the gearbox?
Old 13-01-2010, 21:47   #12
stuey68
[QUOTE=granty;3142878]how about castrol for the gearbox?[/QUO
When Mitsi used to service my car they used Castol in the gearbox. TBH not that impressed. Gear change was notchy and difficult to get in gear, especially when cold. I have been using Millers CRX 75w 90 for a while now. Made a huge difference to the gear change, it is now smooth and precise even from cold
Old 26-01-2010, 21:54   #13
granty
i bought 5 lires to do diff, transfer and gearbox but I only used just under 4 litres is this normal????
Old 29-01-2010, 21:47   #14
ghazevo5
Car: Evo 5
Yup, my clutch was done today... i came away with 6L and only used 4!
Gearbox took 3L
Tranny took juuust under 1L
Hope that helps
ghazevo5 is offline   Reply With Quote
Old 29-01-2010, 21:59   #15
xpro
xpro's Avatar
Car: EVO 8MR FQ400
http://www.evomoto.com/tech_articles..._article_id=26
http://www.evomoto.com/tech_articles..._article_id=25
xpro is offline   Reply With Quote
