Go Back   Mitsubishi Lancer Register Forum > General Stuff > Non-Lancer Chat
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Old 22-12-2009, 09:52   #1
ady_evo
Planning restrictions re: attached garage to the house - Any info much appreciated
Hello all
I am living in a semi detached house and at the moment the house has a detached garage at the end or driveway which is at the left hand side of the house
I've been thinking and would like a garage at the side of the house so its attached to the house. However this is where the queries come in. In order for the garage to be big enough it would need to go right to the boundary of the driveway and at the moment the house is surrounded by a fence. On the boundary of the house is a grass way (about 4 metres in width) which is used by the tractor to get to the field at the back of the house to cut the grass, this is just an empty field and the grass is cut about 4 times a year. On the other side of the grass way are another couple of semi detatched houses.
Subject to putting in an application for building this garage, would there need to be a gap between the side of the garage and the fence which surrounding the house. I really need all the space in order to fit something bigger than a small hatchback in there and need to have the wall built right to the edge of the driveway or boundary.
The other thing is that if it is ok to build a garage wall right at the edge of the boundary of the house. it would need to be at least 8 feet high, however given that the wall garage wall could be right at the boundary, i've heard that you can only build a wall or fence that is 6 ft high.
I feel it may be ok given that there will be a gap between the garage wall and the other house on the left due to the grass way. But on the other hand i will need to take it to the boundary of the house to make a garage sufficient enough in size. Taking the existing garage down would give me more garden room which would be nice and i need to garage to store the car in.
Any help or information or past experiences of doing such an build would be much appreciated
ady_evo is offline   Reply With Quote
Old 22-12-2009, 09:59   #2
Tom Dick
NR555
Tom Dick's Avatar
Car: Evo VII, forged at NR with a 3076
Get in touch with your local planning department, they are desperate for work. Ask them to come & visit to discuss your proposals, be nice, get to know them. It will be well worth it.
NR Autosport if you want a 2.0l 3076 that works
On, on, on screamed the leaders at the back
Tom Dick is offline   Reply With Quote
Old 22-12-2009, 10:02   #3
super rover
acting daft since 1969
super rover's Avatar
Car: E7 RS RALLY CAR
you can build right up to the boundry line no problem ,im not sure about the size of the wall tho ,6 ft is legal for a fence and as a normal garage you could get away with it without planning ,any higher tho youll have to get planning ,but if its the side of your house with no restritions cos theres an access you should be OK
"Of all the branches of men in the forces there is none which shows more devotion and faces grimmer perils than the submariners."
Sir winston churchill
Old 22-12-2009, 10:02   #4
ady_evo
hi mate
When you say planning department do you mean the Council?
Would be nice to know if anybody has had a similar built like that one i want to have just so i can make a case in case of a failed planning permission application.
Adnan
Old 22-12-2009, 10:10   #5
Sider
Sider's Avatar
Are you in England? as different rules/guidelines in different areas.
Building up to the boundary shouldn't be a problem, and the access at the side should be benificial too you as it will keep a gap between you and the neighbouring property, which is helpful. 8' high should be ok as it's only single storey.
Yes you need the Planning Department of your local council for advice.
Sider is offline   Reply With Quote
Old 22-12-2009, 10:18   #6
super rover
Originally Posted by ady_evo View Post
hi mate
Adnan
planning is VERY area permitting ,if i was you id drive round and see if anyone in your area has done something similar ,if so then it could be straight frward ,if not heaven knows
i built right up to my bounder on an old house i started out as a lean to ,then put a side on it but it was hard to see from anything and didnt affect any one then i put a garage door on the front ,i never had an issue when i sold it
Old 22-12-2009, 10:22   #7
ady_evo
hi mate
Yes i'm in England, West Yorkshire
Old 22-12-2009, 10:53   #8
Evoedd
Evoedd's Avatar
Car: Back on the road now, best get driving it!
if you are building up to the boundary do not forget the party wall notice, this has to be done and you will need a solicitor or specialist to organize
steve
555bhp,480lbft thanks to Simon Norris and the 5.5 turbo kit
Evoedd is offline   Reply With Quote
Old 22-12-2009, 11:03   #9
ady_evo
hi
What is a party wall notice.
It is referring to the neighbours as they are on the other side of the grass way which is approximately 4metres side.
Old 22-12-2009, 11:04   #10
ady_evo
steve
hi
Old 22-12-2009, 13:37   #11
stu8
stu8's Avatar
Car: Evo V - geekmapped.com
just checking, you say there is 4m of grass, is that after your boundry?
i'm assuming it is, but was going to say, if its not 4m after your boundry, you'll have to check you are not blocking a right of way access to the field
Stu
Old 22-12-2009, 14:03   #12
PFC
PFC's Avatar
Car: Wingo
Apart from getting the planning sorted you might need to keep mind how you will get access to the back garden after your new attached garage has gone up, bins, garden rubbish etc.
Everything will have to go through the house or garage unless there is another route of access.
As said before, have a walk round your area and see what others have done, that should give a you a reasonable idea about what you can and cannot do and maybe a few ideas as well.
Some councils don't require planning permission for standalone garages under a certain size, whereas they will for a something joined to the house.
Worth checking out yer local councils website, there should be some useful info. that applies to your area.
PFC
PFC is offline   Reply With Quote
Old 22-12-2009, 14:27   #13
Sider
Sider's Avatar
hi mate
Have there been any extensions (including garage etc) since the house was built? If not you may well get it under "Permitted Development" if it is less then 70m cube volume.
Whereabouts in W Yorks? does it come under Leeds?
Old 22-12-2009, 14:34   #14
Bod
Car: GT4 WRC
As other people have said, you'll need to call your Local Council's Planning Department and see what they can tell you.
The rules all change depending on circumstance such as whether you are in a conservation area etc. I'm in the same boat as you in that I should exchange on my new property today (fingers crossed) and am looking to put a garage up when I move in (probably a self build if anybody can recommend one??). I have friends who work in planning, and I shouldn't get any problems (the neighbours have a garage etc), but there were all sorts of rules and regulations! I don't need to apply to planning permission if the garage doesn't exceed a set size, nor should it protrude past the main building. My new garage will be an inch or two shy of the front of the property, so technically, I 'should' be ok, but as I don't fancy having to tage a garage down again, I'll get them to pop by and have a look :-)
Bod is offline   Reply With Quote
Old 22-12-2009, 14:54   #15
ady_evo
Stu
Hi mate
It wont be blocking the access as basically the fence at the moment around the boundary of the house will be replaced by the wall that is the side of the garage.
