Old 05-09-2009, 15:46   #1
EVO7mc
Car: Black evo 8
Question Installing Cams/Bleeding Lifters?
Do you have to bleed the lifters when fitting cams? Watched this video and it would seem not http://videos.streetfire.net/video/H...-on_138721.htm But i've also read that you MUST bleed the lifters can anyone confirm?
EVO7mc is online now   Reply With Quote
Old 05-09-2009, 15:59   #2
starkers
Geekmapped.com
starkers's Avatar
Location: Live in Cambridgeshire but originally from West Yorks....
Car: 2L Forged, 80 series Turbo, Self Mapped Apexi D-jet
Send a message via MSN to starkers
No need to mate, just change the cams over
Engine built and maintained by Mark@Wraith Evolutions
Insured with Pace Ward: 01782 286311
starkers is online now   Reply With Quote
Old 05-09-2009, 16:07   #3
grayw
Geekmapped.com
grayw's Avatar
Car: Evo VIII MR
Release the pressure by depressing the check valve inside, as they will expand when the cams are removed.
grayw is offline   Reply With Quote
Old 05-09-2009, 16:42   #4
leecavturbo
leecavturbo's Avatar
Car: Evo8 gsr
also need another remap
leecavturbo is offline   Reply With Quote
Old 05-09-2009, 17:11   #5
EVO7mc
Car: Black evo 8
Do i need to pump them dry or just release the pressure? Is there a special tool needed or will something like a small allen key or drill bit work?
Old 05-09-2009, 17:13   #6
jamie_v1@evotune
North East Evo Specialist
jamie_v1@evotune's Avatar
Car: Evo 6 Self Built & Mapped 2.3 GT35R Stock Ecu & Maf
It is best to pump them in diesel as that cleans them out a welding rod is ideal to use to unseat the check valve you could also use a small allen key if you wish
jamie_v1@evotune is offline   Reply With Quote
Old 05-09-2009, 18:00   #7
leecavturbo
Car: Evo8 gsr
mike why didn't you fit the cams before mapping?
Old 05-09-2009, 18:58   #8
EVO7mc
Car: Black evo 8
I was offered them after the mapping day at R-Spec, My car had a faulty sensor so I had to go back at some point to get the map finished.I spoke to grayw about the cams before I bought them and he was ok about mapping them in for me when i go to see him
Old 05-09-2009, 20:39   #9
leecavturbo
Car: Evo8 gsr
cool
Old 06-09-2009, 18:13   #10
EVO7mc
Car: Black evo 8
Just out of intrest what is the reason behind bleeding the lifters? Some people do it and others dont.
Old 06-09-2009, 19:53   #11
grayw
Geekmapped.com
grayw's Avatar
Car: Evo VIII MR
They can clog up, so if you have them removed it worth giving them a clean. When the cam is removed the lifter extends to fully open, so getting it back to gether is much easier if you release them.
Old 06-09-2009, 20:24   #12
EVO7mc
Car: Black evo 8
I read that you can somehow end up with bent valves if you dont bleed the lifters http://forums.evolutionm.net/evo-eng...d-first-5.html (5th post down) Is there any truth in that??
Old 07-09-2009, 06:15   #13
jamie_v1@evotune
Yes they can bend the valves if not bled especially if you are running tight piston to valve clearance
vB code is On
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
