Old 23-02-2009, 22:32   #1
naughtyrs
Car: Evo VI RS
87mm pistons
I see wiseco sell 87mm pistons for the 4g63 block running 88mm stroke, I know the block walls would be getting weaker but would ihave problems?
If in doubt, Flat out
naughtyrs is offline   Reply With Quote
Old 23-02-2009, 22:50   #2
Ross W
Ross Sport
Ross W's Avatar
Car: 8.75 @ 163
Send a message via MSN to Ross W
Problem is getting a decent gasket.
Ross W is offline   Reply With Quote
Old 23-02-2009, 22:58   #3
naughtyrs
Car: Evo VI RS
Custom only job then?
Old 23-02-2009, 23:04   #4
Ross W
Ross Sport
Ross W's Avatar
Car: 8.75 @ 163
Yes people are having similar probs on 4G64s with 87mm pistons. Try to stay 86mm if you can. Also like you say the wall get thin and deflection in the block "can" become an issue. Having said that there are gaskets available but its knowing which one to go with! If its lowish power you might get away with a Commetic.
Old 23-02-2009, 23:16   #5
rsjohn
Car: Evo 9 FQ360
ant @indigo sells 86.5mm pistons
2010 Ford Focus RS mk2 - 723bhp 610lb ft torque
rsjohn is offline   Reply With Quote
Old 24-02-2009, 06:53   #6
giangi
Car: Evo tme 2.1 S400 sx76
I have the same problem with a 4g64 block, what about Power Enterprise gaskets? They have a 87 mm one, is it good?
giangi is offline   Reply With Quote
Old 24-02-2009, 08:41   #7
Ian6
Ian6's Avatar
Car: 6 RS lightweight project
Not at all, Power enterprise do an 87mm x 1.5mm gasket
I have used these in a couple of builds and seem to be perfect for the job.
http://www.evasivemotorsports.com/Me...&Store_Code=EM
Cometic also do an 87mm but I have read that there some issues with them.
The Evolution, evolving and keeps getting better :-)
Ian6 is offline   Reply With Quote
Old 24-02-2009, 09:47   #8
youngsyr
youngsyr's Avatar
Car: Evo VIII FQ 330 Sold, now in a BMW M3 (V8)
Can someone clarify this for me:
I understand an Evo head can be bolted straight onto a 4G64 block.
I also understand that 4G64 blocks are routinely bored out to 87mm (they are 86mm standard, aren't they?).
So, if my understanding above is correct, why is deflection and wall thickness an issue on the 4g63 block, but not on the 4G64 block?
youngsyr is offline   Reply With Quote
Old 24-02-2009, 10:34   #9
cossie1
cossie1's Avatar
Car: Evoless :(
Off the top of my head, because the 64 block is bigger as standard (i.e 86.5mm) compared to the 63 having 85mm stock bores.
Or it could just be a stronger block, as it was made for GDI petrol engines which work similar to diesel engines.
cossie1 is offline   Reply With Quote
Old 24-02-2009, 10:37   #10
Ian6
Ian6's Avatar
Originally Posted by cossie1 View Post
Off the top of my head, because the 64 block is bigger as standard (i.e 86mm).
Stock bore for the 4G64 is 86.5mm.
Old 24-02-2009, 10:59   #11
naughtyrs
Car: Evo VI RS
so who has run 87mm pistons on a 4g63 block?
Old 24-02-2009, 11:29   #12
Ian6
Ian6's Avatar
I don't know of anyone recently but I know that RC had
Old 24-02-2009, 11:33   #13
naughtyrs
Car: Evo VI RS
Do i or dont i? 87mm on 88 mm stroke is getting on for a theoretical 2.1litre and nearly oversquare.
Old 24-02-2009, 11:34   #14
Ross W
Ross Sport
Ross W's Avatar
Car: 8.75 @ 163
All ones I have had are 86mm stock
It is also a problem on 4G64 in high power applications.
Old 24-02-2009, 11:53   #15
Ian6
Ian6's Avatar
Ross,
From the info I have they are 86.5mm
From the Wiseco site:
4G64 w/ 4g63 head 2.4L
Kit Part # Bore MM / Inch Over Sizes Stroke Rod Length Comp Height Head cc's Dome/Dish Volume Gasket Thickness Deck Clearance Block Ht. Comp. Ratio Pin Diameter Ring # Foot Notes
K564M865 86.50 / 3.406 Std. 3.937 5.905 1.379 47 -22 .042 .003- 9.255 8.8:1 .827 8650xx 1
K564M87 87.00 / 3.425 .020 100 150 28.7 47 -22 1.1 .076- 235.07 same 21mm 8700xx 1
