| View Poll Results: What Is Your Rev Limit (nearest to)? | |||
| 7700rpm (std) |
28 | 65.12% |
| 8000rpm |
8 | 18.60% |
| 8500rpm |
4 | 9.30% |
| 9000rpm |
2 | 4.65% |
| Over 9000rpm |
1 | 2.33% |
| Voters: 43. You may not vote on this poll | |||
Thread Tools | Rate Thread | Display Modes |
#1 |
Just wondering how many folks raise their rev limits?
Just choose the limit nearest to what you've set. If you're running 8500rpm or more, what mods have you made to the head etc to allow this? Cheers ![]() Rog |
#2 |
8500rpm or it might be a bit more !
For mods see my car |
#3 |
Cheers m8 - do you know the spec of the head - cams, lifters, springs etc btw?
Cheers ![]() Rog |
#4 |
wouldnt know, never hit it
"Our enemies are innovative and resourceful, and so are we. They never stop thinking of ways to harm our country and our people . . . . . . . and neither do we" - George W. Bush |
#5 |
Sorry - there isn't a poll option for that
![]() Rog ![]() |
#6 |
on the limits of adhesion
Good thread Rog, I was wondering what mine would be able to take rev wise if I had the rod-conversion, hopefully ill find out now, be interested what others rev to on a fully forged and stroker etc.
#7 |
Yeah - Chris from Mellon Tuning's vid got me thinking: http://videos.streetfire.net/video/M...whp_210633.htm
I don't really know the exact spec of my motor and am not very keen on solid lifters etc, so just wondered what folks on here had done to keep the motor safe at higher revs... Cheers ![]() Rog |
#8 |
Phil
Is the rev limit set within the ecu? I was told that my car was OK to rev to 9000 and is fitted with Motec M800. Presumably the limit is one of the variable settings within the Motec unit
Phil
#9 |
RC Developments Balance Shaft Eliminator Kit
Full Race Engine Bearing Set RC Developments Race Cylinder Head Stud Kit HKS Metal Headgasket Cylinder Head Race Porting & Polishing RC Developments Spec Piper Camshafts HKS or Unorthodox Cam Vernier Pulleys RC Developments Dual Valve Spring Kit RC Developments 1mm O/S Stainless Steel Inlet Valves RC Developments 1mm O/S Inconel Exhaust Valves HKS Twin Power Ignition System RC Developments Custom Intake Plenum with 80mm Throttle Body RC Developments Custom Intake Pipe Kit |
#10 | |
Evo IV: RGMotorsport built lump 630hp ATF and 600ft-lbs tork). For Sale: Set of Evo 5 17" Oz in Black Chrome with Goodyear F1's |
#11 |
Don't know, would have to ask RC Developments about that.
I remember them telling me it could rev to 9000rpm because its the same spec engine as their race cars ( that is to say all their 2.4 engines are built to the same spec, its just the level of output you ask for that depends on the peripherals used). But I'm sure mine is set about 8500rpm. Last edited by GTIR250 : 14-01-2009 at 19:35. |
#12 |
No point revving out past the power band really. Would need a large turbo (and or massive cams) to make use of revs beyond 7.5krpm imo (again that is capacity dependant 2.0 2.2 2.3 2.4 etc)
Even if i stuck a GT35 on my 2.2 with big'ish cams i wouldn't need to go much beyond 8krpm. Andy
Turbos are like computers, every other month there old technology and out of date. |
#13 |
Car: Evoless atm.
soooooo many variables.
'Its a stone luigi.' |
#14 |
I think mine is 8k, but it may be higher.
I change close to 8k though
Spronsored by LTS PerformanceTEL. 01455 612103 And Pace Ward TEL. 01782 286311 |
#15 |
checking dyno graphs might tell you where to set it,no point rev to 9k if its dropping power by 8k
| Thread Tools | |
