Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 |
bleeding clutch.... have i done it correct???
when you bleed the clutch you push the peddle down turn the bleed nipple then let the peddle come back up on its own then tighten bleed nipple up?
just seen this http://evomoto.com/tech_info.php?tPa...70dcb9622f475b link says pull up the clutch peddle??? i just let it come up on its own with the bleed nipple open? as at first when i opend the bleed nipple to let the air out and closed it back up the clutch peddle stayed down ?? (i thought it would of came straight back up) so i opened the nipple and the peddle started to raise up slowly.... have i done it wrong as it now even harder to get it in gear..... |
#2 |
I could be wrong, but with the bleed nipple open and the pedal raising up, aren't you sucking air into the system?
How does the clutch pedal feel?
#4 | |
Moderator
And after you have put the clutch on the floor you will need to lift it up by hand as it will not come up on its own ![]() Lee
1st 500BHP E5 in the UK Running on Speed Density on Stock H8 Ecu MLR Sprint Scrutineer E5/6 Ecu SD Mapping Info Here & HERE |
#5 |
when the pedal started to raise it was pushing fluid out the nipple so cant see it geting air in but it has made my gears more stiffer so done something wrong.... the pedal feels fine...
will do it correct tomz... thanks guys |
#6 |
Did you get it sorted?
Modified, maintained and set up for track by Performance Autoworks.co.uk 01285 711733 |
#7 |
not bled the clutch yet doing it tomz... its been a pain to get in 2nd gear since doing it wrong last time
just hope that when i do it right it will be ok ish... will get the syncros done in couple of months how much would i be looking at about for the 2nd and 3rd syncros to be done? would the gearbox be more hard to get in gear if i have put to much oil in? |
#8 |
bled the clutch it alot better now in the morning but still got the slight crunch... will get the syncros done next year.... how much would i be looking at about???
| Mitsubishi Lancer Register | ||
