#1 |
Closet Geek
Evo PC Project (Final year uni project)
The aim: to build an in car pc and incorporate full engine data logging, GPS logging, video recording and G-force logging, and then have the above data fully integrated together.
Eventually the data logging can be used on any laptop via plug and play usb connections to the GPS, G-force, cam and engine; just secure your laptop in the car, install the software, plug in the bits and off you go. So far: the PC has been built 1.6Ghz dual core intel atom motherboard 2Gb DDR2 Ram 160Gb Seagate hard drive M2-ATX PSU VoomPc case ![]() ![]() the other parts of the base car pc are arriving or ordered and should all get installed this weekend carTFT 7" TMR open board display ![]() IP67 rearview colour and night vision cam ![]() keysonic bluetooth keyboard + dongle ![]() USB OBDII cable Evoscan beta version (working with Hamish @ evoscan on this) Panasonic slim DVD/RW going in a USB powered external case for plug and play compatability. Seperate leisure battery JL amp and speakers (as the headunit is being replaced by the screen I lose that amplification so a seperate amp must be installed, as for the speakers.... the standard mitsi ones are c*** so i thought i might as well replace them at the same time) bits still to order 3G internet USB GPS receiver USB 3-axis accelerometer USB bulletcam with suction cup mount ![]() will update later as the project progresses Last edited by G3orgi3B; 28-06-2009 at 14:17.. |
#2 |
Jesus built my car
I wrote a naughts and crosses programme for mine. It was unbeatable.
#3 |
Very impressed mate, if you need another car to test it in gimme a shout
keep us posted on your progress Cheers Clay
IF YOU'RE NOT LIVING ON THE EDGE ...... YOU'RE TAKING UP TOO MUCH SPACE
#4 |
Car: golf rallye 4x4 G60 supercharged, FQ-362ish
cool dongle!
What is it?? |
#5 | |
Closet Geek
the dongle isn't in the picture as it was ordered from another company, but i thought i'd include it anyway.
http://www.amazon.co.uk/gp/product/B...pf_rd_i=468294 Quote:
My initial tests will be at snetterton on the 8th of feb, but final tests will probably be around easter time. Last edited by G3orgi3B; 09-12-2008 at 10:34.. |
#6 |
Car: Evo 9 FQ300
Your at university and you drive an evoIX
#7 |
Closet Geek
yup, but it's due to being a mature student and working for a few years before uni.
#8 |
What programming language will you be using? Will it be multi-platform?
Cheers Andy
#9 |
Closet Geek
the language used is visual basic (which i'm learning in my spare time) and the software only runs on windows based OS's atm.
http://www.limitless.co.nz/ my programming input will probably be quite minimul as Hamish has written everything, i'm mostly only going to be tinkering. |
#10 | |
![]() Looking forward to having a sneaky peak at this once it's fully installed and running. |
#11 |
Closet Geek
Hopefully you'll get to see the PC in the car on tuesday night
#12 |
I was talking to my mate and we were going to knock something up like this last year.
There was something like this on the gadget about 8 months back. look like you've covered most of features we talked about; hd video cameras hard wired wifi built in touch screen ect... Good luck with it, who knows make it well and you could sell it on, as i don't think there is a solution or alternative for sale for Evo's at present. I would be interested in something like this myself Last edited by Addo; 10-12-2008 at 07:20.. |
#13 |
I started programming a project in the summer got side tracked though, in C++ and OpenGL, here are some images of the interface, I was going to integrate GPS and inertial sensors to so that you could have a G-meter. I was also working on a seperate program to then visualise the track that you've driven in 3d, changing the colour with range limits
![]() Note the graphing tool shows history, this was using a sine wave to test ![]() ![]() ![]() ![]() You could change the display screen from dials, graphs, bar charts and ODB2 info, although the problem I had was the cable I was using as I could only get 10 updates a second, and I never got round to purchasing one that allows better rates. Sorry for highjacking your thread, but thought it might be of interest Andy
#14 |
Closet Geek
a few more parts have arrived
JL Amp ![]() Slimline DVD/RW... ![]() which I installed in a USB powered external enclosure ![]() the TFT is sheduled to be delivered in the next few days and the car is booked in for the main install on tuesday |
#15 |
Any of you clever chaps care to comment on my thread?
I'm trying to find a gauge solution to work with my Evo 8 and a Pocket PC. I want to be able to show data like in the screen shots above. http://lancerregister.com/showthread.php?t=234827
Trader map Click. How to: Rear seats/Remove shelf/Cam mount/Sidelight bulb/Remove ICS/Fit horn/Tow loop/Refurb carbon |
| Mitsubishi Lancer Register | ||
| Thread Tools | Search this Thread |
