Old 09-01-2008, 22:36   #1
Fulley
Fulley's Avatar
Car: Evo VIII MR FQ 300
cam belt tension?
Im about to change the cams in my 8. What i need to know is what is the easiest way to release the tension on the cam belt?
I only want it slack enough to allow my to remove the cam gear whilst still attached to the belt with cable ties. ( not changing cam gears)
Do I have to fiddle about with the belt tensioner or do I loosen the tensioner pulley? Or is there another way?
Fulley is offline   Reply With Quote
Old 10-01-2008, 00:50   #2
Evo_marv
Evo_marv's Avatar
Car: mitsubishi evo IV, 330bhp
it can be done with cable ties etc and just slide the belt off then back on when cams are changed but tbh on a car like this it would be much better and safer to time the engine up and remove the belt like you would if you were replacing it, as the first initial start up could go either way if it was just kinda guessed and i personally couldnt turn the key lol, there is some good guides on here for timing belt replacement, try the search button
Evo_marv is offline   Reply With Quote
Old 10-01-2008, 02:18   #3
John@FCM
John@FCM's Avatar
dont be a fool do it prop or it will all end in tears
if your old belt has done more than a thousand miles and your realeasing the tension i would put a new one on just to be on the safe side
John@FCM is online now   Reply With Quote
Old 10-01-2008, 03:41   #4
EVO7mc
Car: Black evo 8
You need this part number MD998738 about £10 from mitsy its basically a long bolt that goes into the cylinder head and releases the tension on the belt have a look at this video if unsure
http://videos.streetfire.net/video/e...d00128e555.htm
EVO7mc is offline   Reply With Quote
Old 10-01-2008, 14:48   #5
BigDW
BigDW's Avatar
Car: Evo VIII FQ 330
Also worthwhile doing the balance shaft belt at the same time if it has not been done.
I did mine and wouldn't trust the cable tie method as you could easily be a tooth or more out on the crank pulley if it moves.
BigDW is offline   Reply With Quote
Old 10-01-2008, 19:13   #6
Fulley
Fulley's Avatar
That video makes it look easy. It does say at the start that some steps may be missing!
Can any of the more experianced guys confirm if the video is an acceptable and safe way of doing it?
Old 10-01-2008, 19:25   #7
dearsman
dearsman's Avatar
Car: EVO IX MR FQ360 BY HKS IN PEARL WHITE...
very true mate for the extra hour it will take.. think its got to be done, save the engine and your wallet mate not worth the risk in my opinion ..
dearsman is offline   Reply With Quote
Old 10-01-2008, 19:32   #8
Shit-Happens!!
Have-A-Go-Hero!
Shit-Happens!!'s Avatar
Car: EVO VI RSII
What is the idea behind being able to release the tension like in the video?
Is it to aid a quick replace of cams of the head on a rally stage - I didn't realize you could do it this way I thought you removed the belt as in a cam belt service.
"This is your life, and its ending one second at a time"
Shit-Happens!! is offline   Reply With Quote
Old 04-02-2008, 22:54   #9
bassed
Car: EVO VIII FQ300 (Black), DE-CAT
When I change my cams shortly I'm going to use a similar method. I've only just changed the cambelt and balance belt the traditional way.
However, I am going to check all the timing marks and turn it over with a spanner a few times to check nothing has jumped before going anywhere near the key!!
Not worth the risk of not checking everything to ensure you've not jumped a tooth anywhere imo!
Famous last words of a redneck : "Hey ya'all... watch this!"
bassed is offline   Reply With Quote
vB code is On
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
