Old 31-07-2007, 21:20   #1
jiffy
Car: Evo 8MR for sale
evo 8 mr ACD/SAYC oil change?
ive looked at the workshop manuals and technical manuals
but can not find the correct procedure for changing these oils.
does anyone know how? and apart from the mitsubishi oils what
is good alternative?
thanks
jiffy is offline   Reply With Quote
Old 02-08-2007, 13:06   #2
deadandgone2k
Car: Black Evo 8 FQ-300
I thought in order to do the AYC oil change you need the hand held computer from mitsi to bleed the system back up?
deadandgone2k is offline   Reply With Quote
Old 09-08-2007, 11:21   #3
jiffy
im thought there was a manual way tho?
Old 11-08-2007, 10:15   #4
Stevolution_VI
Standard Steve
Car: Evolution VI
if your changing the oil in the diff its self (low pressure side) it wont require bleeding as its just a drop and refill job like the gearbox. if your chaging the high pressure side oil (the tank in the boot oil) then ul need to have it bled but unless the oil is stinking or uve broken in the into the high pressure side piping for sum reason, it will last yonks. its the oil in the diff itself that requires changing on a regular basis
Stevolution_VI is offline   Reply With Quote
Old 12-08-2007, 16:33   #5
jiffy
yea ive looked at the diff and like you said its just drop and refill.
how often do you change your diff oils and ayc oil?
what do you use?
Old 16-08-2007, 11:53   #6
Stevolution_VI
Standard Steve
Car: Evolution VI
Depends how you use the car, ive only owned mine for a year so done it for piece of mind. its recomended to replace the AYC oil every 4500 miles on a VI and gearbox oils every 18K (I think)
seeing as im not doing the mileage id say maybe once a year or at least every 2 years for the gearbox. the AYC part, at least once a year to keep the squaking away.
for the gearbox/transfer and diff i use silkolene silktran 5
for the AYC, automatic transmission fluid SP3 rated
Old 16-08-2007, 21:04   #7
Evo07
Evo07's Avatar
Car: EVO VIII MR
My MR has had the lot changed every 4k or 6 months
Evo07 is offline   Reply With Quote
Old 20-08-2007, 12:03   #8
jiffy
hybrid do you change the oils yourself?
if so, how do you do the ayc oil change?
Old 20-08-2007, 16:52   #9
Stevolution_VI
Standard Steve
Car: Evolution VI
gearbox/transferbox and rear diff are simple drop and fill items. the AYC low pressure side is the same, and this is also on the rear diff, simply drop and fill, but using ATF SP3 Spec fluid. the top resivoir you wont need to touch and will not require bleeding unless you break into the circuit.
please note that this is the case for my E6 and am guessing its the same/similar for later models. im sure the gearbox and rear diff is as above, but not 100% on the front transfer of the E8 because of the ACD which i dont have......pretty sure its not very different, again provided you drain the right compartment in the box
Old 20-08-2007, 20:37   #10
jiffy
ok thanks mate
