#1 |
Evo VII - IX Model Differences (CT9A)
Evo VII
Import Models Evo VII GSR The Evo VII was the first of the CT9A models and shared the same basic chasis as the VIII, VIII MR, IX and IX MR. In keeping with Mitsi's traditional Evo line up, the top of the range model (in terms of "luxury" options) was the GSR, with the RS being the model designed for competition. Evo VII RS As VII GSR, less: • Air con • AYC • Electric windows • Electric folding mirrors • Brembos • Boot carpet • Enkei alloy wheels plus: • shorter gearing GSR deleted items could be added back as options. Evo VII RSII As VII GSR, less: • Rear wash wiper • Climate control • Electric folding mirrors plus: • air con UK Models Evo VII FQ300 As VII RSII, plus: • Power Engineering exhaust (not all models) • Carbon FQ300 dash inserts • FQ300 carbon inserts in spoiler uprights • FQ badging (not carbon) on centre console & boot • Model # on Slam panel • Foglight in rear cluster • Ralliart panel air filter • Recaro seats (various options) Evo VII GTA As VII GSR, plus: • Low spoiler with LED brake light (large spoiler or no spoiler options) • No bonnet vents • INVECS-II Sport Mode 5A/T transmission • GTA Badging • 15GK compressor housing • 9.0 turbine housing • Slightly detuned engine (272 bhp) • Revised front bumper • Centrally located number plate • Vibration dampening steel oil pan • Steel intercooler piping • Electric wing mirrors • Automatic headlights • Chokepipe in back box • HIDs + fog lamps • Clear indicator lenses • Clear rear lights (inc. indicator lense) • White instrument dials with revised layout including drive selected • Mitsubishi steering wheel incl. mounted shift selector • Centre console incl. auto gear stick • Blue pearl dashboard trim, shift selector & window switch panel • Blue stitching in seats, gear knob & hand brake • Larger seats • Adjustable arm rest with cupholders • Sound insulation in dashboard, floor console, door trim & floor carpet • Lower sash weather strip added to improve door sound insulation • Altered suspension geometry & steering • Matt finish wheels • Leather seats optional Available in [Colours] Evo VIII (Chasis number CT9A 020 XXXX for GSR, CT9A 030 XXXX for MR) UK Models Evo VIII 260 • 2 cats (1 in down pipe, 1 in "normal" position) • 5 speed gear box • 9.8T housing (some with single flapper wastegate) • Slightly modified Evo VII ECU (four plug with two different pins - Earth?) • Euro Style Recaro interior c/w rear adjustable headrests - Leather / Suede option at cost • Non-folding electric wing mirrors • 8 MR pistons & head gasket • No rear wash jet or wiper • Small spoiler with brake light incorporated • No SAS System • UK style Number Plates • Integrated Fog lamp in rear light cluster • Single Din dash • Kenwood 6 speaker CD / Radio system • Large Battery • Bridgestone Potenza tyres • Non HID Headlights • ISOfix points in rear seating • 3x3 Point Rear Seat Belts Evo VIII FQ 300 – as 260 plus: • Upgraded blue/black interior inc. narrower seats • HKS Superdrager catback with HKS downpipe exhaust • 3 Plug ECU • Secondary Air System (SAS) • More aggressive cams • Folding electric mirrors • Double Din stereo slot • Climate Control • Fog light in bumper • Japanese-style front number plate holder • Only one catalytic converter • HKS Hardpipe kit • HKS panel filter • 6 speed gear box • Yokohama Advan A046 tyres • Rear brake light in windscreen • Larger carbon spoiler (body colour paint on outer uprights) Evo VIII FQ 330 – As VIII FQ 300 plus: •upgraded black alcantara/leather interior •piggy back ecu •restrictor in pipe connected to wastegate actuator •smartnav Evo VIII MR FQ 300 – As VIII FQ 300 plus: •10.5T (single flap) housing •upgraded cams •MR seats & door cards •carbon effect dash inserts •dark brushed steel steering wheel •Bilstein shock absorbers •aluminium used in roof & side door beams •Team Dynamic (gunmetal) alloys •black backing to front & rear lights •13 row oil cooler •twin boost solonoid •optimisation and reinforcement of the oil channels in the pistons •uprated 5-ply head gasket •added tension in piston rings, v shaped groove in second land of pistons •reduced weight S-AYC diff (alu casing), higher strength hypoid gears, operates even when ABS is activated. Does not have: •HKS Superdrager exhaust Available in gunmetal grey, not available in black, yellow or blue. Evo VIII MR FQ 320 – As VIII MR FQ 300 plus: • HKS Superdrager exhaust • HKS panel filter • HKS hardpipe kit Evo VIII MR FQ 340 – As VIII MR FQ 320, plus: • Piggy back ECU • Black leather/alcantara interior • Optional smartnav Evo VIII MR FQ 400 – As VIII MR FQ 320, plus: • Forged engine • Limited edition of 100 Custom built Garrett GT Dual Ball bearing turbocharger • Owen Developments custom manufactured cast s/s exhaust manifold & elbow • Omega forged pistons • HKS forged con rods • HKS 680cc injectors • Zytec ITP116 high pressure fuel pump • HKS 1.6mm steel head gasket • Motec M800 OEM ECU • HKS iridium spark plugs • Jan Speed High Flow Sports Cat • Alcon 240mm high clamp mode, HD clutch with Cera-metallic 6 paddle sprung centered drive plate • HKS High Strength Head & Big End Bolts • Alcon Mono6 Brake Kit with Monobloc 6 pot road caliper & 343mm curved vein disc, aluminium bell, Ferodo DS2500 pads • Ralliart carbon effect, electric Aero Mirrors • Carbon fibre front lip • Carbon fibre rear vortex generator • PIAA High Performance light & wiper upgrade • Half leather and FQ400 Logo in Seats optional extra • Gloss black Team Dynamics lightweight alloy wheels Import models Evo VIII GSR – As UK VIII FQ 300 less: • HKS Superdragger exhaust • Foglight in bumper • FQ Badges • HKS Hardpipe kit Evo VIII RS – As Evo VIII GSR plus: • 5 speed box • Stronger rear diff (non S-AYC) less: • Air Con • Alloy wheels • Recaro seats • Electric windows GSR deleted items available as optional extras. Evo VIII MR – As Evo VIII GSR plus: • 10.5T (single flap) housing • Upgraded cams • MR interior • Bilstein shock absorbers • Aluminium roof • BBS alloys • Black backing to front & rear lights • Available in gunmetal grey, not available in black, yellow or blue. Evo VIII MR RS – As Evo VIII MR plus: • 5 speed box • Stronger rear diff (non S-AYC) • Silver backed lights less: • Air Con • Alloy wheels • Recaro seats • Electric windows GSR deleted items available as optional extras. Evo IX (Chasis number: CT9A 040 XXXX) Import models Evo IX GSR – As VIII MR plus: • Mivec • Larger compressor housing diffuser (16G6C) • No spacesaver spare tyre • Gloss black backing to front and rear lights • Rear diffuser bumper • Restyled front bumper with twin oval air inlets • Different size rear oil return to block • Plastic spoiler uprights • Evo IX Enkei Alloys. Available in Cool Silver, Flame Red, Electric Blue, Frost White, Amethyst Black and Solar Yellow. Evo IX GT – As IX GSR plus: • Magnesium Compressor wheel • Titanium turbine wheel • 5 speed gearbox • GT interior • RS Front Diff Set Up (non S-AYC) • Improved drive train Less?: • Air conditioning (Optional Extra?) • Electric Windows (Optional Extra?) • Remote Central Locking (Optional Extra?) Evo IX MR – As IX GSR plus: • Self-levelling headlights • No additional alarm fob (built into key); • Ralliart Wing Mirrors (on some models) • Carbon front lip • New turbo with titanium aluminium alloy turbo fins & reduction in compressor inlet diameter (15.5) • 17in, 11-spoke Speedline Turini alloy wheels • Privacy glass • Lowered ‘Eibach’ coil springs – 10mm front / 5mm rear • Aluminium door sill plates • Piano black dash inserts • Available in Gunmetal Grey, not available in Black, yellow or blue. Evo IX MR RS – As IX MR plus: • RS Front Diff Set Up • 5 speed gearbox • Improved drive train Available in Solid White or Solid Red. Less: • Air conditioning (Optional Extra?); • Electric Windows (Optional Extra?); • Remote Central Locking (Optional Extra?); • Recaro Seats; • IX Enkei alloys (comes with steel wheels). Evo IX RS – As IX MR RS plus: ... Only available in Solid White? UK models Evo IX FQ 300 – As IX GSR plus: • Foglight • PIAA lights and wipers • FQ badges • HKS panel filter Evo IX FQ 320 – As FQ300 plus: • HKS Superdrager exhaust • HKS hardpipe kit • Keyless entry • Ralliart sports pedals • Puncture repair kit Evo IX FQ 340 – As IX FQ 320 plus: • SmartNav • Ralliart Leather/alcantara seats • Remap Evo IX FQ 360 – As IX FQ 340 plus: • Race Cat • Ecutek remap • Speedline 5 spoke alloys • Triple Gauge Din Unit: battery voltage, Oil temperature and Boost (reads up to 1.5bar) • Uprated 225 l/ph fuel pump • Carbon vortex generator • Carbon front splitter • "By HKS" badge on boot Evo IX MR FQ 360 – As IX MR plus: • Race Cat • Triple Gauge Din Unit: battery voltage, Oil temperature and Boost (reads up to 1.5bar) • Ecutek remap • Leather and Alcantara seats with ‘IX MR’ logo (leather delete option) • Carbon Vortex Generator • 6 Speakers fitted as standard (excluding audio head unit) • SAYC changed to give increased torque differential across rear axle • Uprated fuel pump • "By HKS" badge on boot • Available in Cool Silver, Gunmetal Grey, Flame Red, Pearl White, not available in Black, yellow or blue.
#2 |
Car: Evo VIII FQ300 geekmapped
good idea, would be good to get it as a sticky when it's edited correctly.
#3 |
only scanned through it but looks very good. Should be added to the site.
Justice for Turbo_Dan! Let the MLR's charismatic prince of philosophy speak!
#4 |
you missed for the MR's carbon dash inserts. And need to add in the FQ360. + The MR FQ wheels were team dynamics and an import MR were BBS's i think. The FQ 360 had the din gauges as standard
#5 |
Administrator
A lot of this is covered in the Evo Essentials owners guide, but if everyone can add lots of detail I'll find a home for it on the site.
#6 | |
I think the MRs have carbon effect dashes (at least the 2 I have seen have). Thanks to Cryptwalk for all the FQ 400 info.
#7 |
I wasn't aware there was an VIII 360 either in FQ or MR
To my knowledge it was 300, 320, 340 and 400 ? Not that i'm any fountain of knowledge or anything and i'm sure i'll stand corrected soon enough ![]() |
#8 | |
#9 |
yes you're right of course TF, it's just the 9 that has a 360. that's what i must have been thinking about. Be good to get the 9 specs up as well ? There are also some other subtle changes that the 8 MR's over FQ's, they have like a slightly bigger oil cooler, (more layers), and a twin solonoid, etc
#10 |
Thanks evo e, the list has been updated.
It'd be good to get all the CT9A models on there, it's an ongoing project, so I'll work on it over the next few days. Any info is more than welcome!!!
#11 |
Ok guys, I've started on the IXs (see first post), but my knowledge is limited on these, so help me out.
#12 |
PUSSY POWER
nice post buddy, how about adding what cars get ayc rear diffs and what cars get the rs set-up?
#13 |
I will add anything people tell me mate, I just don't know about the RSs etc.
![]() If you do just post up a reply and I'll add it. I'll also get onto the VIIs at some point...
#14 |
MAD mapped
Fuel pump is uprated on the 9 fq360
#15 |
Thanks Nathan, is it just the 360 that has the uprated fuel pump? I remember hearing Oracle say that the 9 pump is superior to the 8 pump?
| Thread Tools | |
