OK so how many of these posts do we need ? :wallbang:
If your car was FIRSTregistered in the UK before March 2001 then you should be paying road tax based on the engine size which will mean £185 paand PLG on your log book
If your new car was First registered in the UK after 1st March 2001 and before 23 March 2006 then your car should be banded in VED bands A-F (most probably F) and should pay approx £205 pa. Logbook should show Taxation class as Petrol Car
If your car was an import registered before March 2006 then you probably got away with a PLG taxation and only pay £185....you are lucky.
If your car was first registered in the UK after 24th March 2006 and it's under 10 years of age when it was first registered in the UK then it should require and ESVA which will mean that you will pay VED based on emissions at the SVA test, probably Band G, which will cost £400pa and again the taxation class will be Petrol Car
Does it matter who pays what, the way the cars were registered was neither consistent nor correct and all that's happened is that some people get lucky and some don't...............
There's no one defined definite answer to the question of "how much is my road tax" unless all the variables are known......It's pretty bloody obvious that a 99 UK EVO 6 will pay £185.......:goingmad::goingmad:
