Old 19-04-2017, 14:35   #1
big_joe
Car: EVO IV
High spec Evo IV - MG forged engine
Welcome to my advert for my beloved 1997 Mitsubishi Evo IV GSR.
Let me start by saying that I absolutely did not want to or plan to sell this car, but with a new baby on the way and some business debts I need to clear, unfortunately it’s going to have to go. Hopefully you can see from the money that I’ve spent maintaining and improving it, that it was never my intention to sell this car, I was planning on keeping it for a very long time .
First let me detail the spec:
Engine internals:
MG Autos built Evo 8 MR FQ engine
Skunk 2 Camshafts
Brian Crower I Beam steel rods
CP Forged pistons
Mitsubishi Oil pump
Mitsubishi Water pump
Mitsubishi Belts and pulleys
Mitsubishi Gaskets and seals
Up rated Lifters
ARP Head studs
ARP Mains
ACL Race bearings
MG Auto spec Ported and polished cylinder head and up rated valve springs
New valves
Lightened, lapped and polished crank by John Wilcox RC
Evo 4 Sump
NGK BPR8ES Spark plugs
Millers 5w/40 FS Competition Oil
Engine externals:
Hel Performance turbo oil line feed and filter – (Head feed blanked)
Hel Performance Large 19 Row FM oil cooler with new custom S/S Braided hoses and Aeroquip fittings
Powder coated blue rocker cover with 2 x -10 breather outlets by Neverneverman
Neverneverman oil breather and catch tank system with powder coated tank and aeroquip hose and fittings
Blue silicone hoses throughout for coolant and turbo pipe work
Turbo and exhaust:
Evo 9 80 Series Turbo
New OEM mitsubishi 80 series actuator
Ported Evo8 MR OEM exhaust manifold and heat wrapped
Ported turbo elbow
Magnex turbo back 3” Decat exhaust system with 5” tail pipe
Fuel and Air:
New walbro 255L fuel pump – hard wired
Large powder coated hard pipe turbo intake and large cone air filter
750 CC RC Fuel Injectors
Tial Anodised blue BOV
Large front mounted intercooler and hard pipe work throughout
Transmission / Drive train:
Exedy up rated Evo 9 Clutch kit
Evo 9 Flywheel
Evo 4 Driveshafts
Evo 6 Gearbox
Evo 6 Transfer Box
Evo 9 MR Rear AYC Diff
New Refurbed Richyx AYC Pump
Braided AYC lines
Management and Electronics:
Evo 7 ECU – Remapped by Mat @ MG AUTOS with Ecuflash
3 Port boost solenoid
HKS EVC-S boost controller
STACK 2bar boost gauge
Battery relocated to boot
Pioneer headunit
Kenwood speakers throughout and door tweeters
Suspension, Wheels, Tyres and Brakes:
MeisterR Zeta R coilovers
J-Speed front strut brace
Rear strut brace
Fast road set up by MG AUTOS
Speedline Corse GT-1 alloy wheels
Yokohama AD08R tyres – 6m tread all round
Evo 9 BREMBO front and rear calipers - Rebuilt
Godspeed grooved discs
Endless MXRS fast road / trackday pads
Hel performance S/S braided caliper brake lines
Motul RBF 600
Polybushed engine and gearbox mounts
Polybushed rear diff mounts
Interior/Exterior/Security
Suede Sparco steering wheel and Lifeline motorsport snap off adaptor
Tinted rear windows and rear screen
Fire extinguisher
Evo V rear lights
Fully under sealed for protection in the UK
Cat1 alarm/immobiliser
Smartrak tracker with active subscription
Some of the more notable work/bills I’ve had done in my 18 months of ownership Include –
Evo 9 AYC rear diff (Evo GB) bought and installed by myself - £450
AYC pump fully refurbed and fitted with new Billet Solenoids by Richyx (still has 7 months warranty) - £700
AYC pump braided hoses - £69
18k Service, Fit new Meister R coilovers ,fast road / track alignment, supply fit and setup HKS EVC boost controller – MG Autos - £1292
New Walbro fuel pump (April 2017) - £86.54
New OEM Mitsubishi IACV – idle control valve - £250
Engine oil sump removed and re-sealed and new custom Oil cooler lines supplied and fitted, TRL - £250
New OEM rear Droplinks and bushes - £69
New Downpipe flexi and slid plate fitted – Tony Banks exhausts - £140
Yokohama AD08R Tyres - £490
Coilver height adjustment and track / fastroad alignment – MG Autos - £100
New Battery £60
Ross sport rear wheel bearing - £118.50
OEM Mitsubishi rear ball joint boots - £26.85
Godspeed front Brembo rebuilt kit - £107.95
Endless MXRS Front and rear pads - £396
Supply and fit OEM IX actuator, flush coolant system – MG Autos - £216
Rear arches rolled – Andy turner Motor sport - £100
New speed converter supplied and fitted - MG - £100
Various receipts for engine oil / transmission / AYC fluids changed by myself
Currently as the car stands, mechanically it needs nothing. The current mileage reading is 189887, which works out to be 129k miles (clocks converted to MPH at 98k) . However, as you can see from the above, almost nothing mechanically remains from the original Evo IV - all engine, suspension, drivetrain, brakes etc are from later model Evos or upgraded .
The engine is a forged unit built by MG autos built in 2010 at a cost of £4106. The engine has only covered 16k miles in that time, and is an absolute peach. It pulls extremely hard and uses minimal oil between changes. I had MG autos remove the old Gizzmo boost controller and replace with a HKS unit which made it pull so much smoother. Power wise, we are not sure as it was last road mapped, but Matt at MG estimated it to be around 420bhp. There’s not much on a track day that will trouble it for straight line speed anyhow.
At the rear, after my rear diff exploded at Cadwell at the MLR trackday last year, I sourced a low mileage Evo 9 Super AYC diff which is apparently the strongest AYC diff available, and at the same time had Richyx from the forum refurbish my AYC pump with the upgraded billet solenoids. This was all fitted with Braided AYC hoses and bled up by Rich. With the AYC now working as it should and future proofed for the foreseeable future, the way the car puts the power down coming out of corners is quite phenomenal. The gearbox and transfer box are perfect, crunch and clunk free.
Chassis wise, I had new Meister R coilovers fitted last year, which are a nice blend of comfy enough on the roads and will harden up to give great performance on the track too. The Geo was last done at the end of 2016 by MG and the car tracks perfectly and turn in is fantastic.
The brake pads are Endless MXRS, which give an amazing balance between road and track. They are useable day to day with minimal noise and dust but really come to life with a bit of heat in them offering great performance with minimal fade. I rebuilt the front brembos last year with new hydraulic and dust seals, the rear calipers were perfect so I left them alone. I have also fitted Yokohama AD08R tyres all round, which once again offer a perfect road and track balance. The brakes and tyres have seen minimal road miles and only half a track day, and so are almost as new.
My MLR project thread documenting most of the work can be seen here –
http://www.lancerregister.com/showthread.php?t=516165
The interior and body work are also in great condition. The only negative points I can think of on the car are -
Drivers Recaro bolster has some wear.
Front Splitter has some scrapes and a crack.
Small rust spec emerged below the passenger side door above the side skirts.
Front drivers side plastic arch liner past its best and rubs on full left hand lock.
Exhaust sometimes rattles against the rear ARB, needs new rubber mounts or hangers changing slightly.
Passenger front door looks to have been painted at some point, in certain lights it looks to be a different slightly shade of silver, not noticeable most of the time.
All these points are pictured below.
The underside of the car is solid with no corrosion holes etc, and the sills / chassis rails are solid. There is some usual surface rust on suspension components etc, I am not an underside polisher by any stretch but everything is solid. I’m happy to jack the car up for any potential buyer to inspect, and I’m sure MG would be happy to provide feedback on the quality of the car as they know it extremely well.
Price wise I’m looking for offers around the £8000 mark. I know this is the top end of Evo IV territory, but comparatively I don’t believe there are many Evos out there offering this much performance for so little money. Please feel free to contact me on 07432554607 if you have any enquires about the car. It is based in Brighouse West Yorkshire if you wish to come see it, but please note test drives will be done by me unless you turn up with cash and proof of fully comprehensive insurance.
The car has 8 months MOT left and it of course passed with no advisories. I'll supply the cat converter and full size front number plate to the buyer for future MOTs.
big_joe is offline   Reply With Quote
Old 19-04-2017, 14:36   #2
big_joe
Car: EVO IV
The below pictures are a combination of some taken today (19/04/17) and a few arty pics from the MLR Cadwell day last year. You’ll also see a pic of the car if you turn to the April page in your MLR Calender .
Bad points
The Following 4 Users Say Thank You to big_joe For This Useful Post:
ant1 (19-04-2017), DuncanIV (19-04-2017), M3 ROB (19-04-2017), paulgtt (19-04-2017)
Old 19-04-2017, 15:48   #3
Mita
Fantastic car mate. Lovely base. GLWTS
big_joe (19-04-2017)
Old 19-04-2017, 19:28   #4
Mikeb1984
Mikeb1984's Avatar
Car: white 9 GT
Great add mate. GLWS.
Evo 9 GT
Mikeb1984 is offline   Reply With Quote
Old 19-04-2017, 19:44   #5
M3 ROB
M3 ROB's Avatar
Car: Evo 6 TME,
Great ad, GLWTS
M3 ROB is offline   Reply With Quote
Old 19-04-2017, 20:05   #6
paulgtt
paulgtt's Avatar
Car: Evo5 GSR
I can't tell you how tempted I am to buy this back!
Good luck with the sale Joe, the car will sell itself, it's a gem of a IV
paulgtt is offline   Reply With Quote
Old 19-04-2017, 20:12   #7
big_joe
Car: EVO IV
Haha hi mate. It would be great if you had it back, then I'll buy it back off you again in a couple of years :lol.
I added up the receipts and I've spent about 5k on it in the last 18 months, it's amazing to drive now!
Old 20-04-2017, 09:13   #8
wardie
Car: EVO 4 BY MG AUTOS AND A 1987 MK2 GOLF
Can i buy it back lol GLWTS, glad to see its still going strong
THE ONLY WAY FORWARDS IN LIFE IS SIDEWAYS
wardie is offline   Reply With Quote
Old 20-04-2017, 12:48   #9
big_joe
Car: EVO IV
Haha of course you can mate. Maybe all three of us should just keep passing it round amongst ourselves?
On a serious note, any prospective buyers can see from the above that this car has a long forum traceable history amongst MLR members, always nice when you can track a cars history .
The Following 2 Users Say Thank You to big_joe For This Useful Post:
paulgtt (20-04-2017), wardie (24-04-2017)
Old 21-04-2017, 13:06   #10
Edkeo
Bargain
Edkeo is offline   Reply With Quote
The Following User Says Thank You to Edkeo For This Useful Post:
big_joe (21-04-2017)
Old 23-04-2017, 19:37   #11
kevy
kevy's Avatar
Car: evov1
I have not been on the forum for a few years with other things happening & selling my 6 I only came on to see what's going on in the evo world & seen this for sale lol
I wasn't looking for a 4 but yours ticks all the boxes for me but I cant pm you for some reason??
Regards Kev
kevy is online now   Reply With Quote
Old 23-04-2017, 20:49   #12
big_joe
Car: EVO IV
Originally Posted by kevy View Post
I have 7k sitting here I was saving up to get another evo & I have not been
I wasn't looking for a 4 but yours ticks all the boxes for me but I cant do 8k as ive only got 7k atm & I cant pm you for some reason??
Regards Kev
You can't PM as you're not a paid up member. My numbers in the advert, give me a text we might be able to come to an arrangement
Old 23-04-2017, 21:11   #13
kevy
kevy's Avatar
Car: evov1
Txt inbound!!!
Old 30-04-2017, 12:28   #14
big_joe
Car: EVO IV
I took a deposit on this but looks like it's fallen through. So, reduced to a bank holiday special price of £7250, no offers. A complete steal at this price but I really need to move it now.
M3 ROB (30-04-2017), ste1 (17-05-2017)
Old 30-04-2017, 17:14   #15
Kwakerswull
Kwakerswull's Avatar
I'd have this if I could sell my hatch sti, I'm after something for the track.
556bhp Norris design tuned Evo 8 (L2esk's old motor)
Kwakerswull is offline   Reply With Quote
The Following User Says Thank You to Kwakerswull For This Useful Post:
scorgie88 (06-06-2017)
