Old 20-09-2016, 22:19   #1
Stevo-evo8
Evo 8 fq330 fully forged, built for 800bhp
Here for sale is my e8 and it pains me to sell it, but as i've now other commitments on buying a house, this as to go! The car as been maticulousy looked after from start to finish and had thousands spent, always been run on shell vpower nitro, and serviced with the best oils fuchs titan pro race s, being a mlr member there as been no expence spared, just recently had a fully forged engine build done by devil developments around 3k miles ago along with new gates timing belts and tensioner, i have a huge folder full of receipts for the engine build and work carried out to the car, the evo is based on the mr model with alacantra half leather/suede seats, momo steering wheel etc, as currently 98k miles on the clock however the engine as only covered around 3k since the rebuild, been built for 800bhp but currently running 1.8bar at 440/470bhp high boost and low boost at 1.4bar at 400bhp on a garrett gt30 turbo, it would achieve alot more with a bigger turbo and clutch/5 speed gearbox upgrade along with a remap, my aim was to turn it into a fully fledged circuit race car but now i've had the change of plan, was last remapped by dynotech with graphs to prove, I'm sure first to see will buy, the only downside is the ayc pump not working properly, i've been quoted £180 by harry hockly motorsport to fix the unit but have never got around to getting it fixed by them, so i will deduct this off the sale price,
Here is the huge spec below
Engine spec
2.0L fully forged long rod engine by devil developments capable upto 800bhp,
New sump fitted
Polished and balanced crank
Honed and decked block
Ross sport Tomei/ kigley anti oil surge kit
New genuine oil pump
Rosssport 3mm lash adjusters
Olliver 156 ibeam longrods
Wiseco forged pistons
Acl rod bearings
Mr head gasket
Arp head stud kit
Kigley valve spring/retainers
New gates 5 piece timing belt kit + oil filter and tensioner,
Acl main bearings, acl thrust washers, arp main stud kit,
New seals and gaskets etc
New waterpump
Headwork
Stage 3 Ported matched and flowed head by ams,
Gsc2 274 cams
Aem adjustable cam pulleys
Turbo and cooling
Big k&n airfilter
Garrett Gt3076 turbo
3" o2 housing with new rosssport lambda sensor,
Shearer fabrications t3 flange exhaust manifold,
3" hks turbo downpipe + straight through hks superdragger exhaust and decat,
Tial 44mm v band internal wastegate
Race developments stage 3 ported inlet manifold with 70mm s90 flange,
S90 throttle boddy
3" hard pipe kit from intercooler to Tb
1000bhp 4" custom made garrett core intercooler made by race developments,
Rspec 3 port boost solenoid
Oil catch can,
Norris designs Mocal 21 row oil cooler kit + braided lines,
12" slimline spal fan
Ngk irriduim 8's plugs
Mr metal recirc dump valve
Fuelling
Rc1000 cc injectors
Walbro 255 in tank fuel pump
Bosch 044 external fuel pump
Sytec fuel pressure regulator
Both fuel pumps hardwired,
Transmission
6 speed gearbox no rattles or clonks
Exedy hd twin plate clutch
Lightened and balanced flywheel
Handling and braking
nankang ns-2r semi slick tyres all round 1k miles ago,
Bc racing fully adjustable coilovers with external resovoirs £1300new
Brembo calipers with carbotech xp8's brake pads all around
Drilled and grooved brake discs all around
Misc
10 months mot
Smart nav navigation
Sony bluetooth cd player
Zaklee clear cam cover
New bosch battery still under 3 yr warranty
Engraved mitsubishi plug cover
Incar pillar pod and boost gauge
Xenon hd headlights
Tinted headlights
Cobra cat 1 alarm
Tracker fitted needs activation
Bad points
Ayc pump fault with pressure
Slight tear on drivers seat
Slight Lacquer peel on rear spoiler
I'm looking for £16800 open to offers, deposits can be taken then final amount to pay in full on collection, Any questions please call me on 07773872986 Regards steve
Stevo-evo8 is offline   Reply With Quote
Old 26-09-2016, 10:18   #2
Stevo-evo8
Bump
Old 02-10-2016, 07:26   #3
Stevo-evo8
Still here
Old 08-10-2016, 11:40   #4
Stevo-evo8
Up
Old 08-10-2016, 11:57   #5
will2
Regional Organiser
will2's Avatar
Glws
Looks fresh and fast in that hue
The Following 2 Users Say Thank You to will2 For This Useful Post:
Evo6er (19-02-2017), Stevo-evo8 (08-10-2016)
Old 08-10-2016, 13:43   #6
Stevo-evo8
Originally Posted by will2 View Post
Glws
Yeah cheers fella
Old 15-10-2016, 14:45   #7
Stevo-evo8
Still here Added some clearer pictures
Old 20-10-2016, 18:39   #8
Stevo-evo8
Up
Old 25-10-2016, 08:23   #9
Stevo-evo8
Bmp
The Following User Says Thank You to Stevo-evo8 For This Useful Post:
r-performance (25-10-2016)
Old 01-11-2016, 08:42   #10
Stevo-evo8
Anyone :-)
Old 02-11-2016, 20:59   #11
EVO8600
User
EVO8600's Avatar
We're you based mate ?
EVO8600 is offline   Reply With Quote
Old 03-11-2016, 08:16   #12
Stevo-evo8
I'm based near Birmingham mate
Old 03-11-2016, 09:05   #13
EVO8600
User
EVO8600's Avatar
I'm viewing one down that way Saturday around the same spec to. Il pm you
Old 03-11-2016, 20:25   #14
Stevo-evo8
Ok mate, can you message me on my number 07773872986 and i will give you my address, not sure if i can reply to pm's on here as my membership ran out a while ago
Drewpal (11-01-2017)
Old 11-11-2016, 20:39   #15
Stevo-evo8
Up
Drewpal (19-01-2017)
