Old 16-07-2017, 10:08   #1
the hunter
senior stroker
the hunter's Avatar
Car: 2.4 Stroker EFR 8374 2.6bar 730ftlb/730Hp New drawers may be required!!!!!!!!!
high spec Evo 7 track car (Group N Based) and Woodford RL5000 transporter.
Due to health reasons i'm having to move on my Evo 7 SLS car .
This car has had no money spared and maintained regardless of cost by DMC performance .
DMC built this car for me from a bare Group N international spec 2002 shell in 2013 it has done very little mileage due to family and work commitments.
ENGINE SPEC:
2.4 stroker (ex RC developments)
4G63 block
Bottom end refresh winter 2016
Balance shaft delete kit
ARP head stud kit
ARP bottom end
Norris design dry sump kit
new head gasket
Strip and rebuild cylinder head
16 new valve exhaust/inlet
kelford 272 cams
bee hive springs
Ti retainers
New valve guides
Adjustable HKS cam pulleys
New lash adjusters
TURBO/INTAKE:
Fullrace tubular manifold
Borgwarner EFR 8374
External wastegate and internal dump valve
Twin Tial wastegates
Oil line kit
4" intake pipe with K&N
Magnus inlet manifold
Custom side exit exhaust with side exit screamer pipes
Bosch 96mm drive by wire throttle body
Custom made 96mm boost pipes
ETS 3.5" intercooler
Mishmoto alloy radiator
FUELING/ENGINE MANAGEMENT:
Syvecs s8 with all the toys on (mapped by matty @MB garage services running a conservative 650hp on sunoco GT plus 109 ron)
Syvecs plex 500 digital dash with GPS and logging
2000cc ID injectors
Spark tech pro 14 cdi COP
Braided fuel lines with an fittings
40l fuel cell in boot
2 x External Bosch 044 fuel pump
1 x Inline filter
Motec MDC diff controller
SUSPENSION/HANDLING:
Car is fully stripped inside except dash board
Polly bushed engine mounts (all 4)
Proflex jumbo 3 tarmac spec coilovers
Rear white line ARB
Front and rear whiteline ARB bushes just fitted
full fia WRC cage fitted
Momentum tubular rear subframe
Adustable rear arms
BRAKES/WHEELS/TYRES:
Works emotion ultimate kai 18x9
225-35-18 toyo r888r which are new (2 sprints)
Alcon 6pots up front with ne XP20 pads
Alcon 4 pots on the rear with new XP12 pads
brake bias valve
ABS delete
Servo delete
RAYS wheel nuts
Custom braided brake lines through out .
GEARBOX/TRANSMISSION:
Mactrax 6 speed sequential gearbox (rebuilt 200 miles ago)
uprated shafts
uprated 65/45 diff
Exedy twin plate clutch (new plates)
E9 RS rear plated diff (by DMC )
ACD transfer box (new clutch pack )
Harry hockley WRC spec diff pump
light alloy prop shaft
Tubular north south bar
EXTERIOR:
Shell is a WRC 2002 fia approved shell (still has the homolgation tag attached)with fully integrated T45 wrc spec roll cage .fully seam welded
Front end converted to tubular .(to allow more space between radiator and turbo )
(ex Gigi Galli )
WRC 2002 kevlar front bumper
custom carbon canards (GWR)
Fibre glass front wings
Front doors light weight alloy WRC 2002 safari rally with very unique carbon door mirrors with built in PIAA spot lights (ex alistair mcrae)
Carbon vortex generator
WRC 2002 rear boot spoiler
Varis carbon bootlid with carbon duck tail spoiler
Carbon window vents
Lexan windows all round
Heated front windscreen
INTERIOR:
Fully stripped except dash
Air bags removed
No sound deadening/carpets
2 x Corbeau pro series carbon seats in date till 2019
330mm suede wheel
Sabelt 5 point harnesses
Switchable maps on dash by means of 12 position cal pot
Kill switch on dash
integrated fire extinguisher
Vbox lite camera recording system with OLED display
Sale will also include:
200 L Sunoco GT plus 109 ron race fuel
Woodford RL5000 race transporter (2015)
which has
fuel and tyre racks
heavy duty fast tow suspension
internal led lighting
3500 kg electric winch
car hold down straps
Price is £60000 for the package ONO
Pictures will follow
the hunter is offline   Reply With Quote
The Following 4 Users Say Thank You to the hunter For This Useful Post:
gafar187 (17-07-2017), GARY-8MR (16-07-2017), Mita (16-07-2017), Realbadman (19-07-2017)
Old 16-07-2017, 10:10   #2
AndySTI
Car: Evo viii - AI autosport 2.3 stroker, 630bhp on vpower
Wow... pics
Sent from my SM-G925F using Tapatalk
AndySTI is offline   Reply With Quote
The Following User Says Thank You to AndySTI For This Useful Post:
the hunter (16-07-2017)
Old 16-07-2017, 10:39   #3
D2
North Scotland R.O
D2's Avatar
Car: 2001 Evo VII GSR, 1999 Evo VI GSR, 2013 Overfinch GTS & Caddy van.
Weapon of a car this! Good luck with the sale Steve
D2 is offline   Reply With Quote
The Following User Says Thank You to D2 For This Useful Post:
Old 16-07-2017, 10:43   #4
Mita
GLWTS , sounds amazing. I hope you are ok health wise.
The Following 2 Users Say Thank You to Mita For This Useful Post:
Realbadman (19-07-2017), the hunter (16-07-2017)
Old 19-07-2017, 09:11   #5
kins
Regional Organiser
kins's Avatar
Car: Evo VI RS
Nice motor - might be worth sticking this one on racecarsdirect.com
Old 19-07-2017, 20:55   #6
the hunter
senior stroker
the hunter's Avatar
Already have done.
Sent from my SM-G920F using Tapatalk
