Old 01-08-2017, 13:38   #1
welded1
evo 4/6 rs sprint race car 2.3 stroker ownns turbo
Firstly can someone tell me how to upload pics as it sayS url of image instead of taking me to browse my pics thanks
Ok so im thinking of selling my evo 4rs as iv had it for a few years and its been very good to me but im thinking of going back to 2wd.
This car has still been motd every year and i will put a fresh 12 months on for the buyer.
The car has completed around 1400 miles if that since having the engine rebuilt to a stroker,all parts sourced from rosssport and built by a long time engine guy who worked for years on wrc cars,
the shell is an evo4 and all running gear and suspension arms etc are evo 6
The first 300 miles of run in done with no boost and 2 oil changes the the next 150 little boost and oil change and so on until it had 650 miles under its belt and then mapped by Bob Rawle very safely.
I will list all i can think off and i have receipts for 99% of work carried out.
I will consider px but if a race car something n/a and 2wd or road cars and jeeps etc.
Probably best to ring me on 07886368604 as i might not list everthing you want to know.
Engine
4g64 crank
CP pistons 85mm
BW 150mm i beam rods
HKS 1.6mm headgasket
Rossport 3mm lash adjusters
Kiggly hla
L19 headstuds
Acl race thrust washer
Acl main and rod bearings
Balance shaft removal kit
Gates kevlar timing belt kit
Mitsi oil pump
Mitshi water pump
Full gasket kit
Arp flywheel bolt set
GT 266 cams and hks pullies
oe spec inlet and exhaust valve set
Kiggly beehive spring kit and steel retainers
Tomei crank oil scraper
Zaklee cam belt cover
Turbo
Rosssport HPBIX journal bearing [less than 700 miles]
Turbo smart actuator
Fp cast manifold [zirotec white coated along with elbow and downpipe]
Every stud or nut and bolt and gasket new
5 zigen elbow and downpipe
Jic magic full titanium exhaust [reasonably quiet]
Always run on castrol 10/60 edge and changed every other outting
Fuel
1000cc rc injectors
Tomei fpr
40 lt tank in boot
Red top facet feeding 2 lt swirl pot
2 bosch 044 feeding engine all done with torques fitting and teflon Braided lines inside car
2 inline fuel filters
Cooling
Mishimoto rad and cap [which i had to modify slighty]
Oe fan on switch
Earls 25 row oil cooler with fan
Mishimoto thermostate
Greddy intercooler which i got new plate and bar core fitted [italian]
Transmission
Short ratio rs box [also have medium ratio to go with it]
oe front rs front with uprated bolts
rs rear diff with new evo x cwp diff was properly set up by clive w
Cusco twin plate clutch
Suspension
KW clubsport v3 with top mounts [less than 700 miles]
Every single bushing or mount is polybushed with caster correction in front wishbones
Brakes
K sport 8 pots with pagis rs29 pads
Brembo rears carbo tech i think
Twin cylinder hydro and original still working
Defi oil and water temp,oil pressure and boost gauges with recording control box,
Alcatek ecu with lc and als activated but never uesed and dont need it and dont see the point other than noise
Cusco dash dodger with door bars
Omp seats in date [drivers is large size]
6 point harnesses [out of date]
Proper working carbon roof vent with dual outlets
Plumbed in fireeater and handheld
Snap off suede wheel
Genuine ralliart sump gaurd
Carbon headlight air duct leading to beatrush cold air box
Beatrush cooler panel
This car is bullet proof and maintained very well,
The shell is rot free no welding only lips of sills beat up a little from jacking
It is very straight but has few little paint scuffs on skirts ana corner of bumper as to be expected
I have 2 spare front bumpers and a splitter
1 spare medium ratio rs box headlights an evo 9 turbo
Set of springs etc etc
There are 4 sets of 17" wheels and 2 sets of 18" and many slicks and wets etc
Car is mapped for sunoco gt260 plus [110 octane]
It made on Bob Rawles VD 503bhp and 538lb/ft at 4000rpm
price wise im thinking 16k for everything but will listen to genuine sensible offers
Evo4/6 rs on 80 series mapped by Bob Rawle
welded1 is offline   Reply With Quote
Old 01-08-2017, 13:58   #2
staffi
TOO many posts.......
staffi's Avatar
Car: Ruri Blue IX GT
Use tinypic buddy to upload your pics
http://tinypic.com/
staffi is offline   Reply With Quote
The Following User Says Thank You to staffi For This Useful Post:
welded1 (06-08-2017)
Old 06-08-2017, 15:39   #3
welded1
http://www.ebay.co.uk/itm/2530732722...84.m1555.l2649
heres a link to ebay for pics cant figure the tinypics thing out lol
Old 06-08-2017, 19:56   #4
big_joe
Car: EVO IV
Looks like a bloody weapon. Good luck with the sale
big_joe is offline   Reply With Quote
Old 11-08-2017, 12:25   #5
welded1
Iv dropped the price to £16k
Id like to here opinions on this
Is it too dear
I know its only a 4 shell but could be made to look 5/6 easily enough
I will accept px actually wouldnt mind a road legal offroad buggy lol
