Thread Tools Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
Old 07-11-2015, 22:13   #1
Juno
Massive Build V11 Wide Body 722BHP Time Attack Road Registered
Deposit Taken SOLD
Doubt I will get to use this now so might sell
Build Just Complete and Unused, Road Registered
EVO V11 Wide Body ready for Time Attack, Sprints, Track Days or Full On Racing in a variety of series.
This car was built from the ground up and taken all the way back to a bare shell.
Gold Lined Engine Bay
Build Up
Everything was either replaced with new or fully refurbished. For the past several months the car has been gone through from front to back by MG Auto Motorsport paying attention to every facet of the build. MG have fabricated everything required to make this a very competent race/track/sprint car whilst being usable on the road.
The car is Mot'd and road legal so you can drive to track days or the shops. It has 6 maps controlled by the Syvecs ECU. The first 3 maps are a Meths/Pump Fuel Mix on Low/Mid/High Boost and the Next 3 are for Full Race Fuel Low/Mid/High Boost. On race fuel the car makes 722BHP at 1.9 Bar
Engine:
Brand new TRL fully forged 2.4 long rod 4G64 race engine with race head and 1mm oversize valves built to well in excess on 850BHP, bespoke TRL plenum! Norris Designs dry sump kit.TZ04 Turbo just fully rebuilt and balanced.
Race Fuel 722 BHP
Pump/Meth Mix 640 BHP
Electronics:
Syvecs S6 ECU
Spark Tech Coil on Plug Spark Control
6 Maps
1-3 for Pump/ Meth Mix at 20%
4-6 for full Race Fuel
Maps are as Follows
Pump/Meth Mix
1- Low Boost
2- Mid Boost
3- High Boost
Race Fuel
1- Low Boost
2- Mid Boost
3- High Boost
Cooling:
All the cooling elements have been fabricated by hand and include Bespoke Intercooler to handle 1000Bhp, Bespoke Radiator with aluminium bracketry designed to make sure the air is forced through the cooling system. Fan located behind radiator for better air flow.
Suspension
BC Racing Suspension with Super Pro Bushes and Castor Kit. Full RollCentre White Line Kit and White Line Anti Roll Bars.
Brakes
AP Racing at the front with new standard Brembos at the rear, F Series Minted Pads all round. AP Racing BTCC Brake Bias Valve, Hel Braided Brake Lines all round. Line lock handbrake system. ABS Removed.
Wheels
Team Dynamics 18x10 at et15 to fit the extra wide body with Toyo 888's
Body
Full Carbon Roof and ACR Wide Body Kit,Custom Fabricated Bespoke Aero Kit to include Front Diffuser with Carbon Dive Planes, Side Aero Sill Extensions, Bespoke Rear Diffuser. Only centre section required if you want a Full Flat Floor. Rear Wing is mounted to the chassis via a bespoke strong but light aluminium frame. You can push or pull the car via the rear wing. It's quick release to gain access to the boot area where you will find a 1000 BHP ATL fuel System. PW PRO Pearl White Wrap with MG Auto Motorsport Graphics.
Fuel System
Bespoke Fuel Cell with ATL Fittings baffled and foam filled with twin in tank bag fuel pumps and external Bosch 044. Special foam has been used which is resistant to Meth and Race Fuel. Twin fuel filters and quick drain valve for switching to race fuel.
Drive Train
New Built RS Differential which is mounted to Skeleton Rear Subframe allowing the removal of the Moustache Bar, much lighter and stiffer. EVO 6 GSR 5 Speed Box rebuilt with 411 Final Drive. Norris Designs Triple Plate Clutch.
Safety
FIA Approved Hand Built Roll Cage by RollCentre Racing weighing only 45 KGS. Plumbed in Lifeline Extinguisher. T45 Seat Rails and Steering Column Support. Corbeau Seats with Sabelt Harnesses.High pressure fittings and braided lines used throughout.
£38000.00
Contact Barry 07968 690681
Essex
Juno is offline   Reply With Quote
Old 07-11-2015, 22:23   #2
Juno
More Pictures
Old 07-11-2015, 22:26   #3
Juno
Fuel
Old 07-11-2015, 22:27   #4
Juno
Interior
Old 07-11-2015, 22:28   #5
Juno
Cooling
Old 07-11-2015, 22:29   #6
Juno
Dry Sump
Old 07-11-2015, 22:31   #7
Juno
Build Back To Bare Shell
Old 07-11-2015, 22:31   #8
Juno
Carbon Roof
Old 07-11-2015, 22:33   #9
Juno
Cabin
Old 07-11-2015, 22:34   #10
Juno
New Engine
Old 07-11-2015, 22:35   #11
Juno
Manifold
Old 07-11-2015, 22:36   #12
Juno
New Turbo
Old 07-11-2015, 22:39   #13
Juno
Quick Release Wing
Old 07-11-2015, 22:43   #14
Juno
722 bhp
The Following 4 Users Say Thank You to Juno For This Useful Post:
Ads9 (09-11-2015), Eddie K (13-12-2015), Realbadman (08-11-2015), spen123 (09-11-2015)
Old 08-11-2015, 03:41   #15
Realbadman
Realbadman's Avatar
Car: Evo x FQ-360 (standard but nt 4 long)
Send a message via Yahoo to Realbadman
This car looks like it's had a lot of work gone into it plus it also looks sick & seem cheaper then the other cars on the same level, good luck m8 on your sale!
Realbadman is offline   Reply With Quote
The Following User Says Thank You to Realbadman For This Useful Post:
Juno (08-11-2015)
